X350 / X358 'HOW TO' quick links
Old 07-08-2009, 07:39 PM
Received 9,010 Likes on 4,113 Posts
Default X350 / X358 'HOW TO' quick links
All posts worthy of FAQdom to be placed here in link form.
Please advise either myself, Caddie or one of the other mods who will arrange this for everyones future benefit
Jaguar Acronyms, Abbreviations & Terms
(thanks to Don B)
Jaguar Original Equipment Manufacturers (OEM)
(thanks to Don B)
https://www.jaguarforums.com/forum/x...2012-a-170578/ X350 vehicle specs
Jaguar Electronic Parts Catalog:
Full Jaguar EPC Download, with complete install instructions.
DOWNLOADS (Assorted Tech files)
XJ_spec/tech_sheets
HVAC Blower Control Module Diagnosis & Repair
https://www.jaguarforums.com/forum/x...er-quit-62390/
HVAC Blower Control Module Rebuild with New Heat Sink
https://www.jaguarforums.com/forum/xj-x350-x358-xj6-xj8-xjr-28/blower-control-module-bcm-rebuild-new-heat-sink-126502/#post1058751
Air Suspension & ECATS System Summary: Components & Operation (thanks to Don B):
Air Suspension & ECATS Summary
Air Suspension & ECATS Jaguar Dealer Service Training Manual Excerpt (thanks to Don B):
http://www.mediafire.com/view/7rdkgg...on_Section.pdf
Front Air Spring/Damper Cutaway Dissection Photos (thanks to reyesl)
https://www.jaguarforums.com/forum/x...-143111/page2/
Air Spring Replacement
DIY Project
Installing Arnott Coilovers X350
Air Suspension
Air Suspension thread; theory and potential solutions authored by a Certified Jag Technician
How to Lower Your X350 (thanks to Cambo)
Key Fob / Remote
Key_fob_facts_all_you_need_to_know
Program Key Fob Instructions #1
Program Key Fob Instructions #2
Windshield Wiper Replacement How To (thanks to edobernig)
https://www.jaguarforums.com/forum/xj-xj6-xj8-xjr-x350-x358-28/how-replace-windshield-wipers-o4-xj-vdp-110698/#post898605
X350TDVi_MAINTENANCE_SCHEDULE_PAGE1 (thanks to BuckMR2)
X350TDVi_MAINTENANCE_SCHEDULE_PAGE2 (thanks to BuckMR2)
Headlight_lenses_clouding
Interior
How to remove back seat
These "how to videos" below are for S types, but should be identical......any issues please advise
https://www.jaguarforums.com/forum/s...ght=intake+air
https://www.jaguarforums.com/forum/s...t=cabin+filter
https://www.jaguarforums.com/forum/x...-plugs-104935/ How to change spark plugs
https://www.jaguarforums.com/forum/x...cement-126855/ Broken ground stud replacement
Color Codes (paint)
Exterior
ELECTRICAL_DIAGRAM
Parts Diagrams (2004-2005) however, it may not be 100% accurate for later models as well
https://www.jaguarforums.com/forum/x...repair-132821/ Door actuator repair
https://www.jaguarforums.com/forum/x...ge-how-119351/ (thanks to Trosty)
Sunroof Repair X350 (thanks to ragman1171)
https://www.jaguarforums.com/forum/x...ir-how-129108/
Supercharger removal (thanks to Jim Lombardi and Cambo)
https://www.jaguarforums.com/forum/x...r-i-pdf-84396/
Transmission
Want to drain/refill your ZF 6HP29 transmission? Here's a guide to getting the proper amount of fluid back into it.
zf-6hp26-transmission-fluid-change-package-kit-sale-44765/
2003-2005 XJR and STR fuel pump repair
https://www.jaguarforums.com/forum/x...esolved-153085
2003-2005 XJR and STR Brembo brake rotor and pad info
https://www.jaguarforums.com/forum/s...r-x350-103513/
Please find below a list of files that will help you to decode your VIN numbers and also help identify your engine, paint, and trim combinations together with control module locations for your car.
X350 Workshop Manual in six sections (thanks to DB6)
Table Of Contents
General Information
Chassis
Powertrain
Electrical
Body
X350 Technical Guide 2004-2005 (Thanks to Gus)
Sidemarker Lamp Service & Replacement (thanks to Don B)
https://www.jaguarforums.com/forum/x...2/#post1074810
Ground / Earth Studs Behind Headlamps: Maintenance and Service (thanks to Don B)
https://www.jaguarforums.com/forum/x...2/#post1156791
Special thanks go to xjrguy for supplying the files.
Daimler Limo.pdf includes Hearse
Series III_en.pdf
X100_en_2000-02_US.pdf XK8 & XKR 2000 MY
X100_en_ROW.pdf XK8 & XKR ROW
X100_en_US.pdf XK8 to 1998 MY
X103_en_US.pdf XK8 & XKR 2003 MY
X150_en_US.pdf New XK range 2007 MY
X200_en_US Part1.pdf S Type
X200_en_US Part2.pdf S Type (shows trim/colour combo’s
X250_en_US.pdf XF
X300_en_US.pdf 1995 to 1997
X308_en_ROW.pdf 1998 to 2000
X308_en_US.pdf 2000 to 2003
X350_en_Final_US.pdf 2003 to 2010
X350_en_US.pdf 2003 to 2006 rough road markets
X351_en_2010 on.pdf XJ 2010 on
X400_en_US.pdf X Type 2001 to 2006
XJ40 a_en_US.pdf 1987 to 1992
XJ40 b_en_US.pdf 1993 to 1994
XJS_en_92 on_US.pdf 1992 to 1996
XJS_en_thru 91_US.pdf to 1992
Jaguar Vin Decoder.pdf Explanations
Some other VIN related tools:
Auto Calculator Site (enter your VIN and decode).
Xclusively Jaguar site (scroll down the page for links to various models) Shown as a chart
Jaguar TSB
Water in the trunk? Possible source and correction.
Special Thanks those pdf files by u10768
How To Remove Front Bumper Cover
How To Bleed Your Brakes In X350
https://www.jaguarforums.com/forum/x...action-145571/
2004_VDP_oil_change
Brake Pad Replacement How To (thanks to edobernig)
https://www.jaguarforums.com/forum/x...e3/#post409524
How To Renovate Faded Wheel Centre / Center Caps (thanks to ericjansen)
https://www.jaguarforums.com/forum/x...5/#post1173811
Attached Thumbnails X350 / X358 'HOW TO' quick links-car01.jpg
The following 50 users liked this post by JimC64:
2catlimit (07-01-2016), 3.6 dave (03-17-2017), AD2014 (05-07-2014), anrod3 (10-17-2013), Bobkirsch (07-29-2012), BobobbySteve (06-17-2016), brother John (05-10-2015), daddywaggs (07-08-2013), DavidNC (12-28-2017), doc (08-08-2013), Don B (11-28-2016), Dunkit (05-06-2016), Easy E (04-26-2014), Ed davies (01-01-2017), FMT (04-26-2014), Got a Jaguar Jones (01-22-2013), GrahamB (02-05-2018), HippyChippy (11-28-2015), James277 (08-09-2015), JCooper (10-19-2013), jimlew (02-20-2017), JimMLiny (10-31-2015), Jimmy280 (06-29-2015), jjd247247 (02-21-2015), Kilowatt3 (02-17-2014), lcmjaguar (08-23-2014), Leodriven (07-11-2013), Maria (09-17-2014), MeatBag (07-11-2014), nail18974 (12-09-2014), NDW (12-28-2015), newbiegurl (03-13-2013), oldish git (10-04-2016), Partick the Cat (05-03-2013), Pristine97XK8Convertible (11-09-2019), ragman1171 (09-21-2014), RDMinor (03-24-2013), ROBERT ALLAN PLUTH (01-28-2018), rsa760041 (10-21-2019), StephenG (11-20-2015), The Moneypit (04-22-2018), thxalot (08-20-2013), timmac69 (05-06-2013), Victor Marquez (11-01-2017), viper1996 (01-23-2019), waynepaulj (08-02-2014), wwr (01-31-2018), Xistnnn (04-07-2015), Zazzy (10-01-2013), Zvonas (08-28-2011) and 45 others liked this post. (Show less...)
Old 09-10-2009, 12:47 PM
Hi all,
please advise of any posts that seem worthy of being added to the FAQ's so that we can update them.
Either contact myself or one of the mods and we'll get it sorted.
This is for the future benefit of ALL.
In the meantime I'm locking this thread so it doesn't get diluted with many responses taking away from the original intention of the post.
The following 13 users liked this post by JimC64:
brother John (05-10-2015), doc (08-08-2013), Jagmandan04 (12-18-2015), jjd247247 (02-18-2015), lcmjaguar (08-23-2014), Leodriven (07-11-2013), marbuch (05-18-2015), Mark Saggese (06-30-2013), oldish git (10-04-2016), Padre788 (02-10-2018), ROBERT ALLAN PLUTH (06-16-2017), Xistnnn (11-01-2013), Zvonas (12-04-2012) and 8 others liked this post. (Show less...)
Old 02-13-2014, 07:35 PM
Is it just me or do we seem a little lighter than we'd like for "FAQ's" & "How to" pictorial posts or vids??
C'mon guys, if you have em, please advise so we can add them to the database.
The following 6 users liked this post by JimC64:
brother John (05-10-2015), HippyChippy (11-28-2015), jjd247247 (02-23-2015), lcmjaguar (08-23-2014), marbuch (05-18-2015), oldish git (10-04-2016) and 1 others liked this post. (Show less...)
Shawn Svacha
02-06-2022 04:53 PM
timfountain
09-17-2015 05:12 PM
Richxk8
09-16-2015 10:57 AM
metalmarty
09-11-2015 07:05 AM
Quick Reply: X350 / X358 'HOW TO' quick links
