Suddenly, no more audio in my "new" XJ8!
Old Mar 4, 2010 | 02:34 PM
ricardoa1's Avatar
Originally Posted by papajag
First, many thanks to all who contributed with their worthy input on my "no audio" problem.
I finally caved and brought it in to the Jaguar dealer and I just learned that the cause was a bad power amplifier (BTW, that was my initial inkling). That's the good news. The bad news is that the part is $1100! As if that wasn't enough, they charge 2 hours of labor to install it. (What they don't know is that I removed it and replaced it once already and it took me about 20 minutes.)
Well, all this is just unpleasant because my 100K mile Select warranty expired 3 months ago and the car only has 34k.
Really love the cat, but no one ever said that love is easy...
Yikes you should have taken the car back and replaced the unit with one from EBAY. I bought one for $100 thinking that was the problem. But I sent it back after trying it and having it not be be issue. Like I said it was the changer. I had a hunch since the Changer did not appear in the display when I pushed the button.
Old Jan 22, 2016 | 07:08 PM
mhessen6's Avatar
Default 2004 XJ8 fm antenna
Originally Posted by androulakis
Not to mud up the thread, but metra makes the adapters you need...
This is Jaguar male to standard motorola:
Car Antenna Connector Adapts aftermarket radio to factory antenna connection - antenna adapter - vw antenna adapter 40-EU10 METRA
And then back
Adapts aftermarket antenna to factory radio 40-EU20 METRA
No hacking or cutting needed.
George
Has this been confirmed? I just picked up my XJ8 last week and was going to add an RF modulated Bluetooth setup. I took apart the dash and pulled the radio to find one little tiny antenna plug at the bottom left corner (so an adapter would be ideal). But normally I would cut it and hardwire into it. But there was a sticker on it that said something about "nav" I didn't want to cut it just in case it was the gps antenna. Then I thought of going straight off the antenna mast when I realized that there is no standard antenna 😳 So needless to say I got frustrated and put it all back together for now. Can someone confirm that these are the correct antenna adapter and that little plug in the back bottom left corner of the nav unit is the actual fm antenna?? I'm desperate at this point.
Thanks!
Old Jan 23, 2016 | 05:29 PM
Torrid's Avatar
This must have happened to my car at some point before I owned it, because I've always wondered why there was sealer along that seam.
Old Jan 28, 2016 | 09:11 AM
Sounds similar to issues I'm experiencing too!
See my thread here, what I've done so far and where I'm at.....
https://www.jaguarforums.com/forum/x...tently-154827/
Old Jul 6, 2016 | 05:04 PM
brittunculus's Avatar
Thanks for excellent content here in this thread. I have lost all sound too. My car sits on a hill facing downwards so water sits in the critical area! I have used a black sealant from Halfords in the UK £5. Granville. Very easy to apply. My Jag is X350 XJ 2003. I am breaking my old 1997 XJ8. Do you think that the amp out of the boot / trunk would be compatible?
Old Jul 26, 2016 | 10:49 AM
Again thanks for tips. (2003 XJ X350). I have now replaced the amp, which had suffered from water. Mine was labelled 2R83-18C808-AJ. It is an 'Alpine'. I believe that the final letter is irrelevant as are also fitted in some X types and S Types. So I widened my scope by searching for 2R83-18C808-A and ended up with a 2R83-18C808-AC which worked perfectly. Just hope that the sealant works well enough!
magmedia
Oct 8, 2015 03:28 PM
MrWhite
Oct 1, 2015 01:43 AM
donald ebanks
Sep 30, 2015 07:08 PM
Rocky15
Sep 28, 2015 04:59 PM
