TSB - Technical Service Bulletins
Old Apr 26, 2010 | 10:33 AM
richard wood's Avatar
Default TSB access
I can't seem to access this TSB you posted on front tire inner wear. If it is still a good web address, can you suggest another way to get it (also interested in the one for brake pad replacement).
https://www.jaguarforums.com/forum/a...3&d=1252684772
Thanks.
Old Apr 26, 2010 | 11:22 AM
H20boy's Avatar
Richard, attachments to the server, including documents and images (not links to outside web hosting sites) cannot be accessed by new members with less than 3 days on their membership and less than 10 posts. Its all explained in the New Member sticky here.
Old Apr 27, 2010 | 11:05 AM
Okay, thanks. I saw the sticky but was hoping for a faster activation than 10 posts since I am in a discussion with the service folks about these subjects now.
Old Apr 27, 2010 | 12:13 PM
H20boy's Avatar
I see, since you need it in a pinch, I pulled the pdf off of the forum server and hosted it on my personal space. You should have no problem getting it now.
Click for a look-see
Old Apr 28, 2010 | 09:20 AM
It is exactly what I need. Thanks!
Old Apr 28, 2010 | 09:29 AM
H20boy's Avatar
You are welcome Richard. Remember to get your post count above 10 to get full access when you've taken care of your alignment. Plenty of threads to participate in. Good luck.
Old Apr 28, 2010 | 09:18 PM
GaryinOregon's Avatar
Jim,
All of these service bulletins and updates are so informative and helpful. Your work on our behalf is much appreciated.
Old Jun 13, 2010 | 01:54 PM
  #28
Ira's Avatar
Ira
>All of these service bulletins and updates are so informative and helpful. Your work on our behalf is much appreciated.<
Ditto,
Ira
Old Jul 16, 2010 | 12:13 PM
  #29
ttwotees's Avatar
Originally Posted by Sarge
Anybody got any information on 2005 S Type, 4.2L, Headlight and self-leveling mechanism? The Jag dealer said they are 1500 dollars each for the new assemblies, but both are shining and do try to come up just a bit when ignition is turned on but only shine out about 10 to 15 feet max. I'm kind of WAG'ing that maybe there is a problem with the self-leveling thingy but I don't even know where to look for it just in case I can find some kind of "Obvious" problem with it.... HELP PLEASE!!!! :-)
Sarge...
I have the certified used car warranty - 6yrs/100,000 miles. Both of mine cratered
early this year and they were replaced under warranty. Dealer said they cost $1,000
each. They actually replace the entire headlight assembly.
Old Sep 6, 2010 | 06:05 AM
  #30
BBiggi's Avatar
Default Thx Jim
MuchoInfo
Old Apr 6, 2011 | 11:44 PM
  #31
Tony S's Avatar
Thumbs up
Excellent listing of TSB's ...... Well done for all the hard work and dedication
Having quickly scanned through them, is there one regarding the test procedures for the transmission rotary switch on an XK8 (MY 1998.75) ?
Many thanks
Last edited by Tony S; Apr 6, 2011 at 11:46 PM. Reason: Forgot to add something ..... Doh!
Old Apr 7, 2011 | 03:39 AM
  #32
JagV8's Avatar
Many thanks
It's not likely to be here - the S-Type forum!!
Old Apr 20, 2011 | 12:27 PM
  #33
Ira's Avatar
Ira
Hi Sarge,
Instead of laying out $3000 to replace the self-leveling mechanisms on my 2006 S-type, I opened the bonnet, took the front cover off and revealed the headlights.
You will see adjusting screws for up/down and left/right.
Adjust the headlamps as if it were a 2000 Ford, ie, park in front of a wall at night and raise the lights.
Very few of us need headlamps that adjust to every bump in the road.
Ira
Old Apr 21, 2011 | 10:52 PM
  #34
vance580's Avatar
Originally Posted by Ira
Hi Sarge,
Ira
Its actually not the self levelers that usually go. Its the housing that holds them breaks and they point at the ground. Here is a link to a video on what to do. I bet if you do that your headlights would most likely level again.
https://www.jaguarforums.com/forum/s...58/#post253826
Old Feb 11, 2012 | 01:40 PM
  #35
tonyu47's Avatar
I discovered that some of the bad links have "&amp;" in the string. if one changes that part to "&" the links seem to work.
hope this helps,
TonyL
Old Aug 22, 2012 | 02:32 AM
  #36
brendanmcquade's Avatar
Thank you this is very helpful
Old Nov 19, 2012 | 09:47 PM
  #37
Diamondrmp's Avatar
Ok I'm a bit confused here. Since this is my first Jag am I correct in that the dealer will not do the TSB's for free?
Other cars I've had they were free at the dealer.
Old Dec 21, 2012 | 01:57 AM
  #38
krzysztofk's Avatar
thanks
Specification-and-Capacity
Power Steering Fluid ? Specification and Capacity 47 for 2004 Jaguar XJ Vehicle Specifications
Old Dec 21, 2012 | 06:35 PM
  #39
clubairth1's Avatar
Community Influencer
It looks like you need to pay to download this??
Old Dec 22, 2012 | 02:15 AM
  #40
JagV8's Avatar
Look for the Vehicle Specs PDF in the stickies in this forum.
