Wheel Shimmy Cured w/ Lower Ball Joints
Old Dec 13, 2012 | 11:25 AM
  #61
smachell's Avatar
Gordo
I have a 1990 xjs, similar issue.
I had the roadforce balancing done, best money spent. massive difference.
I had some wire wheels that wouldn't settle down, much better....
Good Luck, Steve.
Old Dec 11, 2013 | 09:46 PM
  #62
Davebc's Avatar
Default Jtis
I am unable to open the JTIS on my Mac despite several attempts-could someone please post the how to replace ball joints JTIS?
Thank you.
Old Dec 12, 2013 | 04:57 PM
  #63
RaceDiagnostics's Avatar
Remove the old one like this after cutting off the flange.
Getting the new one in is tricky as you need to make a tool.
Attached Thumbnails  Wheel Shimmy Cured w/ Lower Ball Joints-suspension52.jpg    Wheel Shimmy Cured w/ Lower Ball Joints-suspension53.jpg    Wheel Shimmy Cured w/ Lower Ball Joints-suspension73.jpg    Wheel Shimmy Cured w/ Lower Ball Joints-suspension75.jpg    Wheel Shimmy Cured w/ Lower Ball Joints-suspension76.jpg
Old Dec 13, 2013 | 10:52 AM
  #64
lunaticpro's Avatar
Gordo,
Judging from your vehicle pics, looks like you have after market wheels. I too have that slight shake and know that my lower ball joints are bad. I just found the pair for $50 and ordered them to get that fixed but I was also gonna mention something else that may be the cause.
I too have aftermarket wheels and the guy who sold them to me told me to test the wheels out for a bit. He mentioned that if I feel there is too much shake in the steering wheel, I may need a hub spacer (a little piece of plastic that goes in the center of the hub to get a tighter fitting wheel). They sell them at any wheel/tire place and usually run about $40 tops for the set of 4. I plan on doing this after I get my lower ball joints replaced. Just FYI incase you hadnt heard this before...
Old Dec 23, 2013 | 07:32 PM
  #65
Davebc's Avatar
Default R&R lower balljoints on the car?
Anyone tried/had any luck replacing lower ball joints on the car? Found an air hammer adaptor
Says its for Honda/Acura, any reason it wouldn't work on an XK?
Cheap enough tool too, $83.75
Amazon.com: Sp Tools 68600A Honda/acura Ball Joint R&r Tool: Automotive Amazon.com: Sp Tools 68600A Honda/acura Ball Joint R&r Tool: Automotive
Any input guys?
Also, I'm still unable to view JTIS on my Macbook. If anyone can post the procedure for changing out the lower ball joints (or procedure to drop lower arm from knuckle) I sure would appreciate it.
tlynch
Dec 31, 2020 01:58 PM
MrWhite
33
Oct 22, 2015 10:29 AM
Delta66
Oct 4, 2015 05:40 PM
JAMES1944
Sep 29, 2015 11:58 AM
