Air Conditioning problem, need help.
Old Jun 3, 2009 | 10:56 PM
Psych's Avatar
This is interesting because my car does the same thing (well, almost). My A/C does pretty well as I'm driving, but when I slow down or come to a stop, the air doesn't just get warm - it stops blowing. (Nothing changes on the climate control screen, so it isn't like the computer completely shuts it off or anything.) Sometimes it takes quite a while to get blowing strong, cold air again; other times, it starts again right away; and yet sometimes, it continues working as it should as I slow down/stop.
Old Jun 4, 2009 | 09:54 AM
canman's Avatar
I have a similar problem, blows cold for about 15min in heavy traffic and then it gives up. If I restart the car it is fine for another 15min? No one has any idea, compressor and fan seems to be working fine, maybe a sensor fault? If someone knows I would appreciate it too.
Old Jun 4, 2009 | 11:26 AM
MeeMo's Avatar
Red face 99% sure
Originally Posted by fonty14
I have a 2003 X-type and am having a problem with the a/c. It seems to work fine when I am driving, but it gets hot when stopped even just at a light. I have had it to 3 mechanics and got 3 different answers, can anyone help, is this a common problem. One mechanic said compressor, one said expansion valve, and one said condenser fan motor? Thanks in advance.
oh will i was going to post the same thing
btw for the guys who replay u dont have the same problem
but for fonty14 just change the expansion valve i went 2 the dealer ship & thay told my about it is a common problem for x-type but wait till saturday cuz i have an apointment with the dealer ship 2 fix it & i'll be 100% sure about my answer .
(sorry for the bad speling my english is not that good)
Old Jun 4, 2009 | 11:27 AM
faze2's Avatar
My a/c is cold for a little while but then it gets a little warm, not hot though. But it will fluctuate. Sometimes if I roll the windows down it changes back to cold. Any ideas? Maybe it just needs freon?
Old Jun 4, 2009 | 11:30 AM
MeeMo's Avatar
Exclamation
but i'll ask about the problems ur having
Old Jun 4, 2009 | 03:13 PM
christo's Avatar
same here, I read somewhere that it might be a recirculator door not closing all the way. There was a post that if you pull pollen filter out you can see the door and all you have to do it push it closed. can anyone confirm this, or at least point me in the right direction to find the pollen filter?
Old Jun 30, 2009 | 09:26 PM
queenmb's Avatar
Smile
I remember this too and cant find the thread anywhere. Its 150 degrees here in Texas (feels like it anyway) and I need to figure out how to keep this AC cold. Surely some of the old guys (senior members) or techs can help us with this. ..Jim ....anybody
Old Jun 30, 2009 | 10:11 PM
canman's Avatar
ok my problem was fixed, it turned out to need a new recharge by weight, maybe too much water and air in the system causing pressure to show fine on the low side when tested. Well after a complete e-vac, test and refill with 1lb - 13oz of new 134a/oil it is blowing ice cold all the time. The mechanic (ex Jag and LandRover mechanic that opened his own shop) said this would be the first step ($100)... if that didn't work we would look at a bad Pressure Transducer since the Condenser Fan checks out. BTW, blowing warm while stopped is most likely the Condenser Fan....
Old Apr 21, 2011 | 09:58 AM
pnolan6's Avatar
Default 2003 X-Tpye A/C problems
I just joined this site and noticed these old posts, I seem to be having the same issue. Its cold while driving, but once I stop it blows warm. I have checked the fans, both work while the A/C is running, Check the pressure of the fluid and it was slightly high, the clutch is engaging, and even checked the condenser after running the A/C to ensure its not hot (was told if it was hot it could mean bad fans).
Old Apr 21, 2011 | 11:39 AM
Tony_H's Avatar
Have the system properly checked and charged at a good A/C shop. The X Type uses a Ford type (fixed orifice) A/C system. I think when it's low on charge the compressor can't develop a high enough pressure to make the system work. At higher engine speeds (when you're driving) it can develop more pressure so it works better.
Old Apr 21, 2011 | 12:21 PM
pnolan6's Avatar
Tony,
Thank you, I will take it into the shop.
Old Apr 21, 2011 | 01:01 PM
xjrguy's Avatar
I think most folks in this thread will be helped by my response to pnolan6 in his thread.
https://www.jaguarforums.com/forum/x...problem-53501/
Good luck to all!
Old Dec 10, 2013 | 10:24 PM
Bshianne's Avatar
Default No air no heat when not moving
My jag stops blowing heat in winter and air in summer when it is not moving any idea why?
Old May 18, 2015 | 11:24 AM
jkm210's Avatar
Default 94 xjs air conditioner problems, Pls Help!
when I turn the fan on from the dash, sometimes it engages and works fine, other times, there is no fan running at at all or it hesitates, going on and off. Or it fogs up windshield, at first you could hear the fan run but nothing came out of the vents, where do I look first?
JKM210
toronadomike
Jan 22, 2026 10:13 PM
Shawn Svacha
Nov 4, 2019 02:47 PM
jdzubas
Oct 4, 2015 09:14 AM
alpecsa
Sep 7, 2015 11:55 AM
tberg
Sep 7, 2015 07:32 AM
