1996 XJS 4.0L stickyt throttle issue
Old May 11, 2009 | 10:08 AM
rlh6805's Avatar
Default 1996 XJS 4.0L stickyt throttle issue
Hello. My 1996 XJS with the 4.0L has a problem with the throttle. The throttle body sticks when it is closed and takes a slight effort with either your foot on the pedal or your hand on the TB itself to move it. I am wondering if the butterfly itself is sticking on a ridge in the TB, or if it is the lever that the cable attaches to. Has anyone had something similar with this engine?
Old May 12, 2009 | 02:29 PM
BHD2786's Avatar
The throttle body on those cars are very particular. They get dirty very easy and most times if you clean them they are ok... they need to be adjusted properly too. There is a throttle stop that can be adjusted with a tiny Allen wrench...I cant think of the exact adjustment I think its .0002" to .0003" gap when the throttle is closed between the butterfly and the throttle wall. If that is not correct the throttle will stick closed...But be careful the adjustment Allen has locktite on it and it will round off easily...Your TPS might need to be adjusted afterward too
I'm sure that someone here has the correct gap adjustment on the throttle
From my experience if a good cleaning does not fix it the spindle bushing on the butterfly is worn and the throttle needs to be replaced
Hope this helps
Old May 13, 2009 | 09:27 AM
rlh6805's Avatar
Hope this helps
Hello and thanks for the advise!!. I have seen the small throttle stop screw that you mention. I am going to give it a good cleaning and see what happens. I know there has to be a lot of carbon built up in the TB bore. The car was mostly driven on short drives and probably didn't up to proper operating temp too often. I don't think the bushing is worn as there is no play in that piece. It is just sticking when closed.
Rob
Old Sep 7, 2009 | 01:01 PM
Teck4Jag's Avatar
if you spray to much throttle cleaner dirt may get in to the shaft and cause it to stick open,if thats the case you could take it all apart and clean it would be a nice tim to replace the 2 seals,
if it stickes closed you can get away with just a good cleaning and setting the butterfly were the X mark it to .002",but remember the above statement
Old Sep 8, 2009 | 09:43 AM
rlh6805's Avatar
You know, I never did anything except drive it and the sticky throttle went away. Must not have been that bad to begin with.
toronadomike
Jan 22, 2026 10:13 PM
Forcedair1
Sep 8, 2025 01:57 PM
JarodL
Mar 7, 2024 01:39 AM
Gus
Oct 15, 2019 12:29 PM
SouthernGypsy
Sep 3, 2015 10:54 AM
