1997 XK8 rebuild, this is going from bad to worse :o(
Old Jun 27, 2009 | 01:10 PM
wack61's Avatar
Default 1997 XK8 rebuild, this is going from bad to worse :o(
all sorted now, thanks
Old Jun 28, 2009 | 11:01 AM
H20boy's Avatar
I've been wondering about your progress wack, man you were so excited to get that motor apart to see how nice it looked compared to your xk's.
I am no mechanic by any means, so I have no idea why the piston could be seized. I'll follow along and maybe learn something myself. Stay positive, this could still turn out well for you.
Old Jun 28, 2009 | 12:36 PM
wack61's Avatar
there may be hope on the horizon , the cylinder has been soaked in releasing oil overnight, this morning the compression has gone up from 90 to 100psi so we've soaked it again to see if it picks up any more tomorrow.
The mechanic thinks a blast down the motorway might free it off, if not it's head off, new rings, gaskets, head skim
Old Jun 28, 2009 | 05:03 PM
N1XKO's Avatar
Unhappy
Hi Wack ,
Removing the head will not gain access to the rings I'm afraid , the head will not require skimming unless its warped , if thats the case you will need to skim both heads .
I think that your engine problem is more likely to be a sticking valve , get your mechanic to pressurise the cylinder with all four valves in the closed position , if air is escaping from the oil filler cap it's probably rings , if it's escaping from the exhaust it's probably an exhaust valve and if it's escaping from the inlet manifold it's probably an inlet valve ,
Hope this helps ,
N1XKO
Old Jun 29, 2009 | 12:38 AM
wack61's Avatar
Thanks for that N1XKO i'll let him know.
Old Jun 30, 2009 | 12:39 AM
wack61's Avatar
I think you're right about the stuck valve, the psi goes up to 150 when you rev it but then drops back when it's ticking over , he thinks a blast down the motorway may cure it so it'a bonnet back on today and fingers crossed
Old Jun 30, 2009 | 10:20 AM
wack61's Avatar
Originally Posted by N1XKO
Hi Wack ,
It's looking like it's a stuck valve , he's borrowed a camera to have a look inside the cylinder where he can see one of the valves isn't shutting , until he gets the head off he won't be able to see if it's just sticking or bent.
If the head is warped why does the other one need skimming as well if it's OK ?
Old Jun 30, 2009 | 07:21 PM
K.Westra's Avatar
I'm not a mechanic, but I would guess the second head needs skimming to keep the compression the same on both banks. Someone can feel free to chime in and tell me I'm wrong though.
Old Jun 30, 2009 | 09:47 PM
Kevin D's Avatar
I am not a mechanic either, but I do know that you are correct in that you need the same compression, and thus, the same force of energy from the combustion so that the engine is in balance. If one bank had higher compression and more power, the engine would be out of balance and that would cause problems down the line. Also, if one head needs to be repaired, it is likely that the other one would need it before very long, so it only makes sense to do them both at the same time. If one of your front rotors needed to be replaced, you would replace them both, same concept.
Old Jul 5, 2009 | 12:37 PM
wack61's Avatar
Turns out it was nothing to do with low compression, we swapped all the parts from the old engine to the new one, when I bought it the gearbox came with it so we didn't split it, only after asking on here did I find the reason why it ran so badly
The starter motor ring gear is different on the 2 engines, the crank sensor picks up it's reading from the cutouts on the back which are in a different order which is why it ran roughly, I'm surprised it ran at all
saturday was a long day to take the gearbox out and swap them over but it was very rewarding to turn the key and hear it running right, hopefully Monday when it's tested and there are no leaks it'll be on the road after 6 weeks of head scratching and hard work.
Old Jul 5, 2009 | 04:59 PM
H20boy's Avatar
Will keep our fingers crossed for you wack!
Old Jul 6, 2009 | 10:35 AM
wack61's Avatar
well that didn't go well.
the engine is running fine, put it in drive and straight away it came up gearbox error on the display,the D light doesn't come on but it selects a gear which appears to be 4th judging by the performance.
smething is wrong though as the whole car shudders when in forward motion, reverse seems OK , he thinks it may be the cable which selects the gear might need adjusting but I don't know.
This is just one headache after another , I'm really starting to regret ever getting involved with it
Old Jul 6, 2009 | 10:58 AM
avos's Avatar
Sorry to hear, but don't start guessing here, try to get codes, there must be some.
Old Jul 6, 2009 | 11:38 AM
H20boy's Avatar
Remember, new gearbox on old TCM may also be causing computer errors. I'd do a hard reset, and there's that 'learning procedure' (going thru gears in certain order for specific time period, etc) that was required in another owner's experience. Will see if I can think of anything else based on what i've read around here.
Old Jul 6, 2009 | 02:15 PM
wack61's Avatar
sorted now, it was just the gearshift out of position , thanks for the advice it's much appreciated
mrplow58
Jan 21, 2024 05:53 AM
Forcedair1
Feb 19, 2020 01:51 PM
copyman01
Nov 1, 2015 01:01 PM
speacock
Sep 14, 2015 07:57 PM
avern1
Sep 8, 2015 06:25 PM
