DSC fault 2000 S-type
Old Jul 1, 2009 | 06:59 PM
Thermo's Avatar
Veteran: Navy
jagfan, normally with the dsc fault, it is caused by a wheel sensor issue. This should also be giving you an ABS error too. Unfortunately, this is going to require taking the car to a shop with a high end code reader. They will need to access the other computers in the car (not just the ECU). This will tell you down to the sensor that is acting up and causing your problem. From there, it will be down to a sensor, a wiring problem, or a computer issue.
Old Jul 2, 2009 | 08:14 AM
JOsworth's Avatar
Mine came on just after buying my S. The dealer ended up changing the ABS module and the master cylinder. I totally agree that your going to have to get a thorough diagnostic check done since the light can mean a great many things and the error could be anything from a simple sensor to something as big as the repair I had done (under warranty, thank God).
Old Jul 2, 2009 | 03:16 PM
Stevil's Avatar
Mines been on forever, it's the steering angle sensor... just haven't got around to fixing it, I guess it will be expensive as you have to remove the upper steering column to get to it.
Old Jul 3, 2009 | 07:54 AM
JagV8's Avatar
Is the ABS the Teves IV? It may be a dry joint on the circuit board if so.
Very simple to fix.
Old Feb 27, 2011 | 08:28 AM
JagV8's Avatar
Bad battery?
Old Feb 27, 2011 | 09:02 AM
joycesjag's Avatar
Does sound like a failing battery issue. BTW what happened to the "old" motor?
Old Feb 27, 2011 | 02:08 PM
One more vote for checking the battery.
Old Jun 18, 2014 | 04:20 AM
Wasilwa's Avatar
Hi my name is David.
I have Jaguar S Type 2005 model. Two days ago I got it repaired for steering relay problem then after I went to pick it is showed DSC NOT AVAILABLE on dash board.
What could be the problem?
Old Jun 18, 2014 | 04:21 AM
Wasilwa's Avatar
Hi my name is Wasilwa.
I have Jaguar S Type 2005 model. Two days ago I got it repaired for steering relay problem then after I went to pick it showed DSC NOT AVAILABLE on dash board.
Old Jun 18, 2014 | 05:55 AM
JagV8's Avatar
Probably a failing or flattish battery
cissdm
May 3, 2016 06:02 AM
colinc1444
Sep 14, 2015 07:54 PM
Super Cat
Sep 9, 2015 03:24 PM
stype40
Sep 9, 2015 08:14 AM
pocketrocket
Sep 3, 2015 07:44 PM
