Need to replace light bulb in headlight
Old Dec 31, 2005 | 02:08 PM
racerx82's Avatar
Default RE: Need to replace light bulb in headlight
You should be able to twist the rear section off and remove the light and wiring assy...
________
EFFECTS OF PRILOSEC
Old Jan 3, 2006 | 02:44 PM
Patrick's Avatar
Administrator
i also thought that it came out through the back?
Old Jan 4, 2006 | 12:37 AM
racerx82's Avatar
Guess he gave up too easily....
________
T350
Old Jan 5, 2006 | 03:23 PM
Patrick's Avatar
Administrator
ive had several cars which you removed the headlights through the back..although with some of them, you have to remove things like the air box...
Old Jan 7, 2006 | 02:34 PM
racerx82's Avatar
I suppose with the tight engine comparment you'll have to a few things to actually get to the bulb. I looked at it last night and it's pretty tight in there...
________
LATINJANNE
Old Jan 21, 2006 | 06:12 AM
04Xtype's Avatar
i took out mine yesterday to put new bulbs in, its pretty simple once you figure out that there are clips holding the bulb in. open the plastic cap, and disconnect the wire form the bulb, and then theres a clip u need to remove. once thats done the bulb just falls loose and u can remove it.
hope this helps
Old Jan 22, 2006 | 12:18 AM
racerx82's Avatar
Great, thanks for the info
________
**** vid
kurtomatic
Feb 12, 2024 06:58 AM
rudelover2
Sep 11, 2015 08:53 PM
kesslari
Aug 31, 2015 04:53 AM
tonydbaker
Aug 30, 2015 11:02 PM
