jaguar 4x4 problem
Old Jan 20, 2006 | 10:41 PM
racerx82's Avatar
Default RE: jaguar 4x4 problem
Your car hasall whell drive and it's split 60/40 60 for the front and 40 in the rear. As for the snow and ice, having 4 wheel drive will NOT prevent you fron losing control. It works great in the rain, but snow and ice is a differnt beast.
If you want to see your 4 wheel drive in action to make sure it's all working, jack you car up on all four corners and once all 4 wheels are off the gound, start it up and put it in drive. You should see one front and one rear spining....
________
LAMBORGHINI V12
Old Jan 31, 2006 | 02:22 PM
Humy's Avatar
Actually, when I was reading up on the X-Type before I bought it. The car is actually rear wheel drive with a "traction 4 wheel drive" system. So when loss of traction is recognized by the vehicle, power to the front wheels is applied to give the effect of 4 wheel drive. The power distribution ratio is actually 40 front and 60 rear.
I tested this on a snowy day, and slammed the gas at a dead stop, as the tail slightly spun (as if it were a rear wheel drive car), the fronts caught and I blasted through the snow effortlessly[8D].
Click on link that describes the traction system...
http://www.thecarconnection.com/Vehi...183.A3273.html
... relevant info from article... "The new Jaguar Traction-4 drive system, the first ever for this brand, uses an epicyclic center differential that splits torque between the front and rear axles in 40/60 proportion, with a viscous coupling inserted between the front and rear outputs of the center differential that will transfer torque from one tire to the other whenever required to maintain traction"
Thing that scares me, can we rely on a differential?[sm=alcoholic.gif]
Old Feb 1, 2006 | 11:44 PM
racerx82's Avatar
Good info! Thanks!
________
HERBALAIRE VAPORIZER INSTRUCTIONS
X_Type_South_Africa
Dec 9, 2015 05:37 PM
jdzubas
Oct 4, 2015 09:14 AM
Fraser Mitchell
Oct 1, 2015 04:06 AM
johanasu
Sep 3, 2015 12:39 PM
01Silverstone
Aug 28, 2015 09:56 AM
