T S B' s
Old Sep 11, 2009 | 11:52 AM
Default T S B' s
More Jaguar TSB's courtesy of Tbird6.....thanks Tbird, much appreciated
File Type: doc
File Type: doc
File Type: doc
Old Sep 11, 2009 | 11:54 AM
Default More TSB's 1
Seat rocking tsb courtesy of MarkC - Thanks
Sorry guys, but I've deleted any posts made here as I don't want them to dilute the purpose of this thread and make it any harder than necessary for anyone to find what they need
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
Old Sep 7, 2010 | 04:52 PM
Adam Lueb's Avatar
Smile Lights
On your 07 Audi, you haven't melted the headlight covers with those 100w bulbs?
Old Sep 7, 2010 | 07:43 PM
No, they're still fine over a year later thanks for asking
Old Sep 8, 2010 | 02:42 PM
Adam Lueb's Avatar
Smile Lights
Why I commented was about 8 years ago I found Halogen Bulbs for the stoplights for the Benz I owned at the time. I installed them and they were bright, I believe they were 75w. I got stuck in traffic one day on a hill so I had to keep my foot on the brake for about 10 minutes before traffic started moving. When I got home I turned into my driveway shut off the car locked it and walked toward the back and for some reason I looked down at the tail lights. I had a dimple on the drivers side stop light lens, ditto for the passenger side. The halogen bulbs melted the plastic stop light lens. So I changed back to the stock bulb and had dimples on my stop lights for 8 years.
Old Sep 8, 2010 | 02:47 PM
Adam Lueb's Avatar
Smile BHP and HP
I noticed in Europe they quote horsepower as brake horsepower, what is the difference between HP and BHP. Thanks, this questions has bothered me since I bought my first car back in 64, it was a 59 MGA.
Old May 9, 2011 | 04:04 PM
Adam Lueb's Avatar
Smile Headlights
I down loaded the headlight fix from your post, but it won't run on my computer, I am using Window Vista. I did the setup, but when the screen open I get a windows error message saying there is either a download error or the program will not work correctly in Windows, I running Vista. Any suggestions? Thanks
Old Aug 25, 2011 | 10:36 AM
Lcgi's Avatar
Default Jaguar TSB's
Jim,
I have a folder full of Jaguar TSB's (120+) as sourced online.
If you PM me an email address, I can send them for you to add to this collection.
Old Aug 25, 2011 | 11:11 AM
That would be great and much appreciated.
I'll send you a pm re this, thanks, much appreciated
Old Dec 29, 2011 | 10:36 AM
TomTom's Avatar
Talking X-Type 2.5 Throttle Body Problems
I too have experienced the three rotating messages, DSC system fault, Transmission Fault, and one another. This has happened three times, always in cold weather, after defrosting the windshield with the washer fluid (the defrosting kind) and occurred each time within 300 yards or less of the same stretch of interstate only 1 1/2 miles from home. I looked it over carefully and noticed the wiring for the throttle body was very tight having no play to wiggle them whatsoever. Cold contracts so I reason they shrink just a bit, not so good it they are tight when warm. I disconnected and rerouted them so they now have a little play and you can deflect the wire with your fingers now. This doesn't mean the problem won't come back or this is the definitive answer, just a good-sense precaution. I have removed the wiper cowl and put a flexible black plastic barrier that "domes" over the top of the cabin pollen filter. This makes it impossible for the filter to get wet unless you deliberately used a garden hose sprayer and shot it in at an angle through the grill in the cowl on the drivers side. I don't know what this black plastic thing is I cut the material from. It was my brothers and he passed away 5 years ago so I can't ask him about it. It is rolled up, has rounded corners and what looks like two "handle holes" (also with rounded corners). The wiper cowl back in place holds this down. I made sure it didn't protrude over into the driver's side moving mechanicals for the wipers.
Additionally, if I ever have the Throttle body Sensor issue (which I haven't) I have seen a write-up on the Ford Ranger 3.0 throttle position sensor that makes it adjustable. That's not important here BUT it tells you where to connect a voltmeter to the sensor wiring so you can read the voltage at idle or WOT (wide open throttle). This proceedure (minus the slot cutting for a Ford) I believe could be used on our X-Types to check and see what the proper voltage is before removing the sensor to clean it. That way we could be sure to put it back where the computer needs it to be instead of eyeball guessing. If memory serves, they all operate about the same electrically with power coming in from the computer (+5 vdc not 12), a ground or common wire, and signal (varying voltage) out. Just a thought.
Old Dec 29, 2012 | 10:55 AM
kccode1's Avatar
Since this is sticky thread about TSBs
I found this link. I Don't know it is all the TSBs but it must be most of them.
Old Mar 16, 2014 | 05:39 PM
TomTom's Avatar
Default Update to fix for problem
Moisture entering the engine computer was the problem with drop out of throttle and three messages, transmission fault, DSC System failure and Cruise not available. The fix I described took care of the problem as a water diverter.
The computer is half way between the engine compartment and passenger cabin on the passenger side. Worst of all, it's in there tilted downward on the back and upward on the front edge. Water gets on the wiring harness and runs down into the connector. I also coated the connector with a generous amount of white lithium grease spray as an additional water barrier.
The problem as not returned.
Old Mar 16, 2014 | 07:34 PM
Lcgi's Avatar
Arrow
Thanks for the update TomTom.
Can we all assume that you are referring to a USA configured Vehicle ?
(Left hand Drive)
Which means your mentioned 'Passenger Side' is on left side of vehicle - when you're standing in front of and facing the car ?
Does your information hold true for location of Computer and mentioned leak path issues - for ALL Models of X-Type ? (US or EURO)
