Headrest tsb as advised by Doug. Nice one
Fuse charts, convertible top, trasmission control module and tensioners as advised by Test point - many thanks
__________________
Jim
I wished the buck stopped here. I could use a few.
I started out with nothing, and I still have most of it.
Despite the cost of living, have you noticed how it remains so popular?
Its hard to understand how a cemetary raised its burial costs and blamed it on the high cost of living!! MY2007 Audi A6 3.0 Tdi SE Quattro 176bhp Stratos Blue, Front & Rear park assist, Comms Pack High, Sline grille badge, 17" TT Trapeze alloys, Rear tints, Dipped bulbs 80W, Mainbeams 100W, Foglights 100W, Number plate bulb LED's, Interior bulb LED's, First Aid Kit, Bootliner, Mudflaps front & rear, Calipers & hubs painted. MY2004 VW Passat 1.9 Tdi Highline LANG MAY YER LUM REEK
__________________
Gus
XK8 1999 117,000mi
S-Type 2000 66,000mi
Rav4 1996 264,000mi and counting www.gusglikas.com/autorepair.htm
What it is what it ain’t and what it ought to be!
Don’t ask the question if you don’t want to hear the answer!
In theory, there is no difference between theory and practice. But in practice, there is.-Yogi Berra
Insanity: doing the same thing over and over again and expecting different results.-Albert Einstein
This is a Word file. I am using Firefox and Windows 7. I have Word 2003 (with a converter for Word 2007) I see no way to open this file or to save it to my hard drive. If someone knows how to open it, please let me know...Thanks
I don't know why you are having trouble downloading the Word file but here it is in .pdf.
Bottom line is that the TSB was issued in August '99 at the start of the '00 model year. If your car was assembled after that you should have the green Pentosin fluid. Check the manufacture date on the driver 'B' column. Check the color of the fluid in the reservoir. The earlier fluid was yellow. Top up if low and green, flush if yellow.
There is also a common problem with the top lift rams leaking without much sign of escaped fluid. If reservoir is low you have a leak that must be fixed.
Also an excellent time to install the pressure regulating system before you blow the hoses which I am surprised hasn't happened yet. Mine blew at 40k mile, 4 year intervals like clockwork . . . three times.
Remember, new members, with less than 10 posts and 3 days of membership (both must be achieved) cannot download or view 'attached' documents. Please read the New Member thread as the MUST READ for all new registered members.
Are you a newly registered member?If so, please read about the forum guidelines, the short term access restrictions, and get some advice on getting started --> HERE.
Send me a PM - 4 sale > OEM head unit w/cass (from premium system), black leather skin from back seat (backs only), XK8 overriders and chrome splitter for grill
