Oil Filter
Old Sep 12, 2007 | 10:10 AM
bigdreams05's Avatar
Default RE: Oil Filter
No need for a Jaguar oil filter...believe me! I do suggest getting the mobile1 or the K and N if they make it for the X. The last time I did my oil change I used a K and N, which makes the removal of it VERY easy compared to any other oil filter. That's a 100% guarantee. Whatever you do though...DONT USE A FRAM! YOU FRAM IT, YOU BLOW IT!
Old Sep 12, 2007 | 10:31 AM
Cadillac's Avatar
OEM parts are the best for any car but I would only use WIX as an aftermarket replacement
Old Sep 12, 2007 | 01:20 PM
tokaygecko's Avatar
Last I checked the only aftermarket oil filter manufacturers that use drain-back valves in their products are K&N, Mobil 1, and Amsoil. Stick with those or go with OEM Jaguar filters. Wix are very good filters but if they do not have a drainback valve I wouldn't use them.
On our cars the oil filter is mounted almost vertically, which means once the engine is off gravity will drain the oil from the top of the engine through the oil filter into the oilpan. The drainback valve is basically a one-way valve that allows oil to flow in the correct direction when pressurized, and keeps oil from flowing back once the engine is off. It ensures that you have a thicker oil film on all lower end bearings for a cold start.
NO FRAM!!!!! FRAM is junk.
Old Sep 14, 2007 | 12:51 PM
RudyF6's Avatar
Buy Motorcraft filters - FL-400-S fits 2.5 and 3.0. And it hasthevalve in question.
aholbro1
Dec 29, 2024 06:46 PM
Scarecrow
Mar 28, 2016 03:17 AM
axr383
Sep 18, 2015 11:19 AM
teacoff
Sep 10, 2015 08:25 AM
pnwrs2000
Sep 3, 2015 11:55 AM
