transmission question?
Hear lately sometime when I move the selector from park to reverse nothing happens. However all I need to do is go from either reverse back to park and then back to reverse or from reverse to neutral back to reverse. Then it will go into gear. I want to think it is some sort of bad/dirty contact in the selector or something simple. I cannot afford any major events right now. Any ideas guys.
No codes nothing on the display either.
1999 xk8 coupe 70K.
1999 xk8 coupe 70K.
Well I guess i have to answer my own questions now. I spoke with the service writer at Jaguar about my issue. He suggested bringing the car in and have the linkage adjusted. Basically he said they have seen this problem with the S & X types but not to many on the XK's but that is not to say that it doesn't happen. He felt pretty confident that it was a linkage adjustment because I told him the shift sequences were spot on. He estimated it would be no more that and hour but probable only a 30 minute job. If that is the problem. I'll keep you all posted.
Well I guess i have to answer my own questions now. I spoke with the service writer at Jaguar about my issue. He suggested bringing the car in and have the linkage adjusted. Basically he said they have seen this problem with the S & X types but not to many on the XK's but that is not to say that it doesn't happen. He felt pretty confident that it was a linkage adjustment because I told him the shift sequences were spot on. *****He estimated it would be no more that and hour but probable only a 30 minute job****. If that is the problem. I'll keep you all posted.
aholbro1
08-05-2021 05:02 AM
