Newbie - XK8 Headlamp moisture
Old 11-10-2009, 11:28 AM
nilocp's Avatar
Default Newbie - XK8 Headlamp moisture
Hi guys, I am new to this site, so bear with me if it has been asked before.
I am getting alot of moisture in my 2001 headlamps.
I believe there is a mod to vent them?
Where do you actually drill a hole please?
Colin
Old 11-10-2009, 01:14 PM
Gus's Avatar
Gus
Gus is offline
Jag has a TSB 417-05 on this for cars 1997 to 2004. In short is is suggesting that you drill a hole in the light assembly if it do not have a hole and in either case install a vent. From what I understand do not take the light apart and attempt to clean the reflective area. I have been told that is not a good idea. As for a location send me a PM and I will send you what I can.
The following 2 users liked this post by Gus:
Dr. D (01-26-2022), Terry Young (09-29-2014)
Old 11-10-2009, 07:59 PM
brgjag's Avatar
If you want the moisture out short term open the hood and on top of the hear light capsuls is a cover that has three prongs/clips holding that cap on. Just rush in on the prings and pull up. If you have FAT fingers it may be a little hard to do. I just left mine off this summer. No moisture. The moment I put them on, drivers side in my case it get moisture right back. I have not got any water in my light capsule with that cover over. Just make sure it is covered if you have hood open and cleaning anything.
Leaving this cover off going to be an issue for me?
The following 2 users liked this post by brgjag:
PWC (01-13-2014), rickjensen (07-08-2014)
Old 11-11-2009, 07:28 PM
Gus's Avatar
Gus
Gus is offline
Colin
This is what you are looking for.
Attached Thumbnails Newbie - XK8 Headlamp moisture-headlamp1.jpg   Newbie - XK8 Headlamp moisture-headlamp2.jpg   Newbie - XK8 Headlamp moisture-headlamp3.jpg
Old 11-12-2009, 07:19 AM
RJag's Avatar
Default Headlight moisture
As usual, Thanks Gus.
BTW, that T fitting has a curve in the bottom. Just where do you find these?
Old 11-12-2009, 07:36 AM
Gus's Avatar
Gus
Gus is offline
I have no idea! The first place I would go is Jag... Looks like the TSB has a part number.
Old 11-12-2009, 08:46 AM
BobF's Avatar
Default Part Number for Vent
Lje 4133 aa
Old 11-12-2009, 08:58 AM
Gus's Avatar
Gus
Gus is offline
Well Hello Bob! How have you been?
Old 11-13-2009, 07:38 AM
stremsjg's Avatar
Thanks brgjag for the tip on removing the moisture inside my headlamp lens, it worked like a charm. It took about 2 days for the moisture to evaporate. I will close the cover and report back to the forum if the moisture returns.
I like Gus's suggestion for a vent tube, however I am unable to read the thumbnails even when I enlarge. Any way you can resend but larger?
Old 11-13-2009, 12:16 PM
H20boy's Avatar
The permanent vent is the long term solution, however, popping off the clear cap after a long storm event can fix you pretty quick. I never installed the vent, and leave my clear lids only partially secured, and about once a year, a storm fogs the lamps. I just deal with it.
Old 11-13-2009, 06:56 PM
RJag's Avatar
Smile Vents
Got digging around mine and lo and behold. The mod has been done. The little 'T's are a white rubbery material. The lights were drilled with about a 3/16th's bit and I'm betting that the hole is still too small since my right one fogs after a wash. I could also have a bug in it or something since there is one small dead spider on the bottom. I'll pull it in the spring when it's warmer and open up the hole.
Old 11-14-2009, 04:16 PM
V6 JDT's Avatar
My mod had been done also but they still steam up pretty bad on one side. Jag are now replacing the lights under warranty. You don't want to know the price of them
Old 01-23-2010, 07:19 PM
BurgXK8's Avatar
Default warranty?
Your car is a few years old - isnt your warranty expired by now?
Old 03-25-2010, 02:14 AM
97xk8dee's Avatar
thanks for the info on clearing lens....97xk8dee
Old 11-04-2010, 08:25 PM
Fla Steve's Avatar
Why can't I open the pictures for where to drill the headlights?
Old 11-05-2010, 02:40 AM
H20boy's Avatar
steve, still having problems with the pics? they're very small. A link to the TSB is also in our FAQ thread at the top of this subforum, just in case you want to try there.
gluck!
Old 11-06-2010, 06:34 PM
T6driver's Avatar
Default Headlight fogs up when washed but then clears
On my 2006 xk8 the driver's side headlight fogs when I wash the car but it clears up quickly. Do I need to do the mod? (unable to view mod pics right now, not enough posts I think) Thanks for the help.
Old 02-09-2011, 03:29 AM
jagosaurus's Avatar
I drilled a 8mm hole where the Jag update tells you to and problem solved.
Old 10-14-2012, 03:41 PM
jagosaurus's Avatar
Update, repainted both my headlights black and replaced the lens cover on the driver side, the light with the new hole free lens cover does NOT get water condensation inside, but the lens with the hole DOES. (Nights get cold and moist here).
So, seems to me that a lens with a perfect seal will not lead to condensation buildup? I've tried to remove the cover for the problematic side and will see if that helps, maybe it just needs MORE air.
Old 01-26-2013, 09:34 AM
Stingrayc2's Avatar
Default Condensation
Was looking at new headlight covers and new rubber.
Includes seals and chrome and glass cover at a cost of 250 per side.
I wonder if that would solve the condensation problem.
Jag vented my lights andd still getting condensation on a sunny day.
Jag tells me thet is common but I do not know.
Would it be wise to get the new seels and covers with the chrome piece of
just live with the condensation
Quick Reply: Newbie - XK8 Headlamp moisture
