Rollbar
Old May 17, 2006 | 01:48 AM
04Xtype's Avatar
Default Rollbar
Does anyone know if there is a rollbar available for the x-type, i got some 18X8.5 rims, and every time i have people in the back and take a turn a little quick, the tires on the back rub on the fender. I've looked around, but can't find anything for the x. Also does anyone know where to get a short shifter?
Thanx
Old May 22, 2006 | 02:12 PM
racerx82's Avatar
Default RE: Rollbar
Unfortunately no, no company makes a roll bar for the X type. That will have to be a do it yourself project.
Besides, how is a roll bar going to stop your fenders from rubbing on the incorrect size tires you have? To fix that problem you'll need to roll out your fenders, or raise the rear about 1 inch using air shocks or an air bag.
By "short shifter" I'm guessing your referring to the manual trans shifter handle to select the gears quicker with very little throw's giving your trans a quicker shift. Unfortunately for that, no, there is nothing like that out there for the jag x type, it already has the short ,throw shifter. You can't improve on something already perfect... lol
And to save you from further troubles, there are no aftermarket companies that make: headers, intake, and any other engine mods. ( i looked)
Here is one good company that you can look into: http://www.racinggreencars.com/moder...aguar%20X-Type
Good luck in your search.
________
ULTRAM REHAB FORUMS
Old May 24, 2006 | 07:23 AM
04Xtype's Avatar
Default RE: Rollbar
haha, true there is nuffing aftermarket out there for our cars, but if ure looking for intake, jaguarxp.com have one, but im not to sure how good it is, i ordered it once and got back ordered for like a month so i cancelled it.
Thanx anyways
Old May 24, 2006 | 07:44 AM
04Xtype's Avatar
Default RE: Rollbar
The tire size i have on it is 225/40/18, i thought that wud fix the rubbng but it didnt, before i had some 255/35/18 which rubbed even when no one was sittin in the back when i went over a little bump. it also rubbed when i revved up to 4500rpms and then shifted, i think it cud be my suspension, im thinkin bout changin it, ne ideas of what to change it to? I heard that KW make coilovers, but only the front is adjustable.
Old May 24, 2006 | 03:47 PM
racerx82's Avatar
Default RE: Rollbar
You need to put the 17 inch back and that should fix your tire rubbing problem. You're right about the coil overs, only the front is adjustable. As for the rear, I admit that the springs are somewhat loose and you get that chicken squat when you accelerate. Only way to fix that is to order the Arden spring kit which drops the rear another 1.5 inches. Looks sweet and I love it. I run my originally low profile 17's and don't have any problems with tire rubbing on the fenders.
As for the intake, yes, they have one, but I was referring to the intake manifold.
________
Bmw M06 History
deadboy1977
Jan 19, 2017 12:12 AM
weisberg
Mar 25, 2014 12:56 AM
cohibarandy
Jan 15, 2013 10:07 AM
pjkbrit
Sep 28, 2010 04:02 PM
