Replacing speakers in X-Type
Old Jun 28, 2006 | 10:53 PM
racerx82's Avatar
Default RE: Replacing speakers in X-Type
Ok, here goes....
If you have the alpine system you will see on the rear deck lid your sub with an amp. If you don't have the rear speaker on the deck lid than you don't have the alpiine.
Your current speakers run off your stock head unit. The speakers in the door have clips and once you take the clips off, your speakers will come out. As for the size, I forgot to measure them! Sorry.
If you replace your stock speakers with something better, it won't help you since the stock radio though looks nice, really doesn't deliver the quality you expect. I just replaced my headunit with a Jensen 6.5 flat screen radio. much better quality!
hope this helps...
________
How To Roll Blunts
Old Jun 29, 2006 | 08:45 PM
racerx82's Avatar
Hmmm, you're going totally opposite as to what I did. I kept my speakers (I thought they were good) and just replaced the head unit with this one check it out: http://www.cardomain.com/item/JENVM9021TS
This head unit has more features and I didn't need an amp to get the quality I wanted. Plays all known CD formats and takes SDRAM chips for truly on the go music, not to mention all the other features it has......anyway, sorry I got carried away...
I did install a 12 inch sub though...with built in amp. I ran the power wire from the sub through the trunk, under the door sills, then around and under the shifter. Under the shifter you will find a rubber piece where the Auto shifter bolts to the floor and cable goes through floor. I just moved it to run the wire, then under the car and carefully around to the battery. (Avoid any sharp edges and hot exhaust!)
As for your speakers, I really don't know the size, but the door panels are easy to remove and you should have no problems. The panels are held in place by plastic clips that you'll have to gently pry to remove. Run your speaker wires through the original current location, boot located on side of door.
If you're a DIY kinda guy, you should have no problems. Took me 3 days to get my stuff set up. just remember, in your case you're dealing with lots of wires, so I would be real careful as to not cross any wires and start a fire...(seen too many with these kids shyt rigging everything) if you're not sure, best bet is to pay someone and have it done right.
Good luck
________
Kitchen Measures
Old Jul 1, 2006 | 12:55 PM
racerx82's Avatar
[IMG][/IMG]cool, good luck ace
________
JUSTIN BIEBER
Old Oct 10, 2006 | 07:55 PM
racerx82's Avatar
cool, and congrats...your GF got herself a sweet ride and you better keep an eye on her....
find one of my post with the radio. It has lots of photos of the radio and entir car with the suspension dropped and other stuff.
I'm working on the battery now...moving it to the trunk....balancing act...got a 12v tire pump and tire repair kit (like what BMW does now) No spare....shaved approx 20 pounds so far.
Pics will follow soon...
________
Murci?lago
Old Oct 10, 2006 | 09:48 PM
aquill1's Avatar
You have the full sized spare? I have the original 17" aguilla in my trunk you could probably get a couple hundred for it!
Old Oct 11, 2006 | 01:00 AM
racerx82's Avatar
Na, i'll hold on to it......just incase.....
________
KIDS PRILOSEC
Old Nov 3, 2006 | 12:10 AM
racerx82's Avatar
That be correct
________
BIG **** MATURE
Old Nov 3, 2006 | 09:29 AM
andersen06's Avatar
How hard is it to take off the door panels??
Old Nov 3, 2006 | 06:55 PM
andersen06's Avatar
Ebay has some clips...
http://cgi.ebay.com/jaguar-door-card...QQcmdZViewItem
Old Nov 3, 2006 | 09:16 PM
nineball's Avatar
you can pick those door clips up at any local auto parts store for much cheaper than that. i needed some on a previous car i owned and got a box of 25 for around $8 a year ago or so. they are a universal part for the most part. just bring one with you so you can match up the depth of the part.
Old Nov 4, 2006 | 12:44 AM
racerx82's Avatar
Door panel is kinda hard...use of force is required and if you're careful you'll be able to save the clips...
________
Ship Sale
Old Nov 4, 2006 | 10:57 AM
andersen06's Avatar
Im gonna try and pull the front doors off today. So just to be clear, Its gonna take force to pop the clips out(Ill try to be careful). Then I just have to disconnect the wiring harness and of she comes...There's no screws or any hidden surprises???
Old Nov 4, 2006 | 11:30 AM
racerx82's Avatar
Once you take the the 2 (I think) screws off from the door arm rest....no surprises....just some tender force....
Lets us know how it goes..
________
UGGS
