How to change a Fuel pump module on a a xtype
Old Jul 28, 2010 | 08:29 PM
number1stun's Avatar
Default How to change a Fuel pump module on a a xtype
Please help anyone
Old Jul 29, 2010 | 03:28 PM
billbjork's Avatar
I read up on it.--quote-- drain fuel,disconnect fuel lines and wire harness, drop tank,replace unit, reassemble. removing the filler pipe/vent could be a trick. unit price aftermarket $600.00. Don't forget to disable pump circuit(relay)before. don't dry test pump. sounds like a two man job with a lift.
Old Jul 30, 2010 | 10:14 AM
Default umm No
the fuel pump module is under seat. remove rear seat, pull floor carpet up a little and tuck in a little cavitiy.. jus took my out yesterday. but thankx anyway
Old Jul 31, 2010 | 08:32 PM
billbjork's Avatar
sorry for the misinfo guys looks like I got bad web info I'll be more carefull who I get info from without double checking.
Old Aug 9, 2011 | 05:36 PM
Sienlee's Avatar
Hi #1stun,
are you sure your car is jaguar x-type? are you sure you took its fuel pump out of a cavity in the rear seat? I think I need to change the fuel pump for my 2003 jag x-type 2.5. Can you/someone confirm it? And where is my fuel pump relay?
I answer my questions by myself now.
No, there is no fuel pump relay in my car (confirmed with the dealer) since my car has a fuel pump module packed with the fuel pump.
No, there is no cavity for you to pick up a fuel pump assembly in the rear seat.
I have bought this used fuel pump module assembly from ebay by paying $80.44 including shipping fee. a mechanic will come and change it for me soon.
Attached Thumbnails How to change a Fuel pump module on a a xtype-dsci1519.jpg
Old Aug 9, 2011 | 10:59 PM
mohrd's Avatar
What year is your X-Type. Any instructions I've ever seen on the pump or module start with "remove fuel tank..."
Old Mar 28, 2013 | 07:43 PM
Terry Campbell's Avatar
Help please im replacing my fuel pump got everything off now seem like module is stuck how do the module come out the tank
Old Apr 7, 2013 | 09:13 AM
AlfaVeloce's Avatar
The module the OP is referring to is the pump's electronic control module which is under the rear seat in 2.5 and 3.0 powered cars. 2.0 cars I gathered have a fuel pump control relay in the power distribution box under the hood and no module under the seat.
I read a thread recently that had good info on removing the actual pump. If I can locate it again I will link it here.
Old Apr 7, 2013 | 09:21 AM
AlfaVeloce's Avatar
Found it...
https://www.jaguarforums.com/forum/x...-advice-92399/
dsnyder586
Dec 29, 2024 07:39 PM
Sprayall
May 30, 2021 08:13 AM
Charlene n John
Sep 28, 2015 06:01 AM
Charlene n John
Sep 6, 2015 11:03 AM
Sprayall
Sep 3, 2015 07:49 PM
