Will 20in wheels fit?
Old Jul 11, 2006 | 12:30 AM
Supralative's Avatar
Default Will 20in wheels fit?
Stock suspension with no springs.
Will 20inch wheels fit.
I know of 19in wheels fitting, not sure of 20's.
Does anyone have pics of their X Types with aftermarket wheels? If so please post up.
Photo Gallery isnt woring for me nor is the search function.
Old Jul 13, 2006 | 05:19 PM
racerx82's Avatar
Default RE: Will 20in wheels fit?
Stock suspension with no springs on a jag with 19's?? No way dude..fogetabout the 20's too. Another crazy question, why?
________
Montana Marijuana Dispensaries
Old Jul 14, 2006 | 03:19 AM
there was a post with the Bonspeed Jaguar out of Cali
it had 19's on it
and it looked like it had suspension work
just wanted to see...figure it would decent
leaning towards 18's with a drop now though
get me some pics when you can though
if you can contact me at
supralative@yahoo.com
i want to do a stereo also but want to keep steering wheel controls
found a stereo on ebay but not sure if the 2003-2005 stereo will work on the 2002 model
thanks again
Old Jul 15, 2006 | 01:57 PM
racerx82's Avatar
I thing they had to roll the fender to get the 20's to fit.....or get the adjustable coil overs so that you can raise the rear and front by at least 1 inch. Other than that, you can forget about having passengers...your wheels will rub...all the time especially where the road has imperfections.... 18's will fit just fine, unless you remove the coils then forget about it....
As for my stereo, i wanted to keep the steering wheel controls, but the kit (for now) doesn't have it...Jensen is working on something.....maybe in the next few months i'll have someting that will interface with radio and wheel......
As for now haven't had much time to finish it, hoping by next weekend to have it all done....
________
LovelyWendie99
Old Jul 16, 2006 | 09:32 PM
alright
so you are saying 18"s with a drop isnt possible??
i saw a sport type at the dealership here
they have the stiffer springs, not sure if it lowers it, but the 17"s they had still had plenty of gap
i am hoping i can get 18"s on there with a drop
i will go wheels first and then see how much room is left
shoot me some pics though when you get a chance so i can see yours
Old Jul 19, 2006 | 09:14 PM
racerx82's Avatar
No, I think i said, 18's with NO SPRINGS is not possible. Same with 20's.
I have the stock 17's with the Arden coil overs lowered 1.5 inchs and they work fine. I can see 18's fitting....but putting items in the trunk or 4 people in car is asking for trouble. If it's just you and a girl, 18's and the lowered Arden suspension (designed for the Jag) should be ok.
If you look at the Bonspeed jaguar, it has fatter rear tires with the lowered springs....but look closley and you will see they rolled the rear quaters to make them fit.
You can make anything work....you'll just need lots of $$$$ or a good friend in the bodyshop business....
________
The cigar boss
Old Jul 19, 2006 | 09:15 PM
racerx82's Avatar
I'm trying to figure out how you post pictures here......been a member for a while now and still trying to figure it out!! Help!
________
Pornstars cruz
Old Jul 20, 2006 | 01:26 AM
How much of a drop was the Arden springs and where and how much did you pay for them?
I am gonna do the wheels first and see how it sits and rides with and without people in the car.
Fender work is no prob hehehee. I put a 17X11.5 in the back of the Supra with 315/35/17...with some work.
H&R advertise 1.4 in front and 1.5 front and back or it might be 1.3 and 1.4 for the drops.
If you have the pics hosted somewhere you should just be able to put the image tags around it.
Old Jul 20, 2006 | 09:35 PM
racerx82's Avatar
Arden Springs were 250 (front and rear) I just did the rear, dropped it a bit more than 1.5 inches. I took measurements prior to doing it and it's more like a 2 inch drop for the rear. I decided not to do the front....so if you want to buy the front Arden springs from me, let me know. Right now I have about 1 inch clearance in the rear from tire to fender. Thinking of installing fatter tires to give it a bit more aggressive look. Should be no problems if I stick with the 17's
Pics are on my laptop, I’ll take more once I wash it and wax....
Arden stuff here---->http://www.arden.de/
Other cool toys here---->http://www.jaguarxp.com/jagxp/Xtype_Exterior_page.htm
Good Jag engine info here----->http://3litermotorproject.blogspot.com/
And finally---->http://www.racinggreencars.com/moder...aguar%20X-Type
BTW, you know anybody that makes custom rims?
Old Jul 20, 2006 | 11:17 PM
I dont know of anyone on a personal level.
The wheels on the Supra were somewhat custom. They are the only ones that could fit a wheel that wide on the rear and front and still clear calipers, and stay with the wheel wells.
They also made a 16in drag set up that I ran on that car also. That was alot hard using 16"s to fit the front calipers.
www.ccwheel.com
he has some other styles now but he caters to higher end cars and track cars usually
FIKSE has some stuff on their site
you can print it out and take measurements and they can possibly make you some wheels
there is a local shop here that can get Bogart centers and weld the barrel and center together but they couldnt do anything with my Supra back then to accomdate the brakes and all
Old Jul 22, 2006 | 05:39 PM
racerx82's Avatar
Cool...i think i'll wait..
I have some other ideas....but for now i enjoy what i have
________
INFANTS WELLBUTRIN
Old Oct 3, 2006 | 12:21 AM
aquill1's Avatar
19's wont fit without modification? Even with lower profile tires?
Old Oct 3, 2006 | 08:41 PM
racerx82's Avatar
I suppose you may get 19's with stock suspension......and thats with the low profile tires.....You may get rubbing when corning and pot holes...
lower your suspension and the tallest low profile tire you can get to work safely is 18....notice i say safely.......ask me how i know.. lol
________
WENDIE 99
Old Oct 3, 2006 | 10:47 PM
aquill1's Avatar
how low are we talking? The 17" konigs on my car now have a 35 series profile. How low are we talking i'd want to go with on an 18" or 19"? I wish I had the stock aguilla's on mine but these konigs are growing on me. What size rim offset and all do I need. I've heard that some gms have a similar bolt pattern and offset. If this is true my buddy bought a set of 18x9's saleen wheels for his century. What width in inches will allow an 18" rim to fit on these x-types. Whats the max. Wondering if I could go with a 18x9 and 18x10 in the back! Just wondering though...
Old Oct 4, 2006 | 04:26 AM
nineball's Avatar
i run 225/40/18 with no changes to the suspension and no problems.
i still need to snap a new picture. the wheels in tis are clean, but the tires had a bit of residue from being mounted, nor does this show the painted cilver calipers.
Old Oct 6, 2006 | 09:55 PM
BuckMR2's Avatar
There are 20" wheels on this X type:-[sm=yikesomg.gif]
Supercharged X Type with 20" wheels
Old Oct 9, 2006 | 09:53 PM
aquill1's Avatar
I read your link to that a while ago...Didn't it say something about the alteration to the car to fit them? That is a sweet car though. My tires are series 45 not 35 like I originally stated. Does anyone know what offset the rims need to fit?
Old Oct 10, 2006 | 07:38 PM
racerx82's Avatar
offset is like 45 i think...45-48 some way off not normal number.......that's why only a certain few rims will fit correctly.
________
Child avandia
Old Oct 29, 2006 | 08:11 PM
aquill1's Avatar
I am seriously looking at the mille miglia which only come in 19" from tirerack.com The site only shows rims that fit from my understanding (possibly just the offset numbers and that not necessarily them actually fitting.) The cost per rim are 189 which is a pretty good deal and they looook very nice. They look like something like Jag would put on the car stock too so I think they'd look nice. I am wondering that if I had the 225 35zr19 whether they would fit or not without bottoming out? I am going to go to belle tire and see what they say.
Old Oct 29, 2006 | 08:26 PM
racerx82's Avatar
Cool, let us know
________
Wendie 99
