Jaguar Technician Information System (JTIS) download
Old Feb 1, 2008 | 03:44 AM
Default RE: Jaguar Technician Information System (JTIS) download
Nice one tg
FAQ'd n locked
Jim
Old Feb 1, 2008 | 09:15 AM
Opened up again as per request from jvegas.
Jim
jvegas's Avatar
thanks!
Old Feb 1, 2008 | 10:05 AM
Dennis's Avatar
ud
A very helpful tool for the DIYer..Nice one tg
Old Feb 1, 2008 | 03:17 PM
jvegas's Avatar
it did not work for me. did any one else get it to work?
Old Feb 1, 2008 | 05:04 PM
Humy's Avatar
how do I get it onto a CD? - it looks liek it belongs on a disk
Old Feb 1, 2008 | 06:07 PM
jvegas's Avatar
no it is a compressed file. but it wont unzip.... help
Old Feb 1, 2008 | 06:23 PM
Markus's Avatar
Worked fine for me, but took me a bit to unzip, setup, etc.....huge file, glad I have cable modem.
Super, TG - Many thanks!
________
1999 XJR
Old Feb 1, 2008 | 06:32 PM
tarheel72's Avatar
downloaded and unzipped fine, but as stated in the OP post, set up will not work with Vista. I think it is because it is a 16bit program and Vista runs 32bit environment. Anyone know how to open this and set it up on Vista?
Old Feb 1, 2008 | 06:51 PM
FactoryJaguarTech's Avatar
JTIS.....ahh how antiquated....lol
I am glad you all getting some much needed info.
Old Nov 16, 2008 | 10:01 AM
christo's Avatar
Same here - I would be willing to host the file for others!
Old Nov 16, 2008 | 04:54 PM
crashdata's Avatar
xp = x32 bit &x64 bit O/S.
Vista = x32 & x64 bit O/S.
So this shouldn't matter.
but when installing under vista try this.
1.) right click on the installation file (i.e setup.exe)
2.) select properties
3.) click on compatibility tab
4.) under compatibility mode make sure to check the box that says "run this program in compatibility mode for:"
-this will enable the drop down list then select. XP service pack 2.
This also works with other program that you might want to migrate to Vista
hope that work
Old Nov 17, 2008 | 02:30 PM
crashdata's Avatar
can someone let me know if this method worked for them?
thanks
Old Nov 17, 2008 | 07:49 PM
queenmb's Avatar
I believe the current issue is not the OS, but the fact that the site where the download was found no longer exists or has moved.
Old Nov 18, 2008 | 07:07 AM
christo's Avatar
Anyone know where we can get it now?
Old Nov 18, 2008 | 03:11 PM
crashdata's Avatar
has anyone tried torrent?
