XK8 Throttle Problems
Old Feb 1, 2008 | 09:37 PM
FactoryJaguarTech's Avatar
Default RE: XK8 Throttle Problems
If you got a p0121 then it is def a throttle problem.
Before replacing throttle, disconnect tps and look at pins. If you gave gold pins on tps and tin pins on harness side,
this could be the problem. You need to replace the tin pins with gold ones to correct concern.
Old Feb 6, 2008 | 06:28 PM
remosusa's Avatar
does the pin extraction tool come with the pins?
Old Feb 6, 2008 | 07:02 PM
No but they are not hard to get out.
toronadomike
Jan 22, 2026 10:13 PM
99xk8guy
Sep 29, 2025 10:51 PM
Gus
Oct 15, 2019 12:29 PM
ajacks86
Oct 12, 2017 08:51 PM
