2005 X Type security failed code...HELP
Old Jun 6, 2005 | 07:01 PM
racerx82's Avatar
Default 2005 X Type security failed code...HELP
Hi all,
got a new 05 Jag X type and love it! Car rides and handles like a dream! Orginally went to purchase a 05 Monte Carlo ss and came across the Jag Dealer and WOW! More bang for the buck.
Ok, so here is my problem. I got a new instrument cluster that has more fetures and when i installed it, a light flashed and on the display of the cluster it read, "Security Failed" And the vehicle will not start. I re-install the orginal cluster and all is fine.
Is there a way to re-set it?? Or am i screwed here?
Also, when i did that my windows all had the one push and they all go down and or up, now i have to hold the button for the window to go all the way down and up....
is there a cure for my baby??
________
The hills forums
Old Jun 18, 2005 | 08:21 PM
racerx82's Avatar
Default RE: 2005 X Type security failed code...HELP
Mine is an 05 and i wanted to swap out clusters from an 03. I guess i'll need another 04 cluster to make it work.
________
Avandia Settlement
Old Dec 21, 2005 | 10:56 PM
racerx82's Avatar
What tool does the dealer use? Any part numbers? Name? can it be bought at the dealer?
________
The office advice
Old Jan 17, 2006 | 09:47 PM
racerx82's Avatar
20K, is that all? Can it clean my car for me?
________
Homemade Vaporizors
Old Jan 6, 2014 | 04:57 PM
ward1724's Avatar
Question security failed on dash
I have a 2004 xtype and it failed the smog because some of the lights on the instrument cluster are out so I got another which came from a used one and replaced it and it wont start and says security failed... called the dealer and they said I have to buy a new one. Any ideas? Ive seen programming instructions but one problem is I dont have a FOB, just a key...
Old Sep 10, 2015 | 03:03 PM
Alessandro Denitto's Avatar
I've the same problem. I've replaced the instrument cluster and on display "security failed" and "gearbox fault".
Someone have solution?
Old Sep 12, 2015 | 03:52 AM
JagV8's Avatar
It's part of the immo so car has gone into anti-theft. Dealer tool to get it out or maybe putting original cluster back might work.
Old Sep 13, 2015 | 06:26 AM
x_type_lpg's Avatar
the instrument cluster is part of the security system (transducer in key engine ecu and instrument cluster) you need to use the sdd software to install a new cluster. you will need two keys as the software erases all the data before it reprograms the cluster. the milage reading can be the new cluster or the difference between the old and new readings as the cluster holds a copy and the engine ecu another copy
way2far
Aug 31, 2022 09:26 AM
Shawn Svacha
Nov 4, 2019 02:47 PM
Raul Lara
Sep 14, 2015 07:31 PM
pnwrs2000
Sep 3, 2015 11:55 AM
dcvickers
Sep 2, 2015 06:14 PM
