Lowered Jaguar Problem
Old Apr 23, 2008 | 12:45 PM
KAZsam's Avatar
Default RE: Lowered Jaguar Problem
Don't get insulted but, did you put the correct coils in their place
front/rear?
Old Apr 23, 2008 | 01:02 PM
ArdenX's Avatar
Sounds like that would be a logical solution. It supposed to be the opposite, where the front looks lower and the back is slightly higher.
Old Apr 23, 2008 | 01:33 PM
jagxtype's Avatar
I'm with kazsam on this one
Old Apr 23, 2008 | 02:18 PM
jvegas's Avatar
pics??
Old Apr 23, 2008 | 04:25 PM
ArdenX's Avatar
Yea, I definitely think we need some pics for our amusement, err, I mean for a proper analysis.
Old Apr 24, 2008 | 05:25 PM
MarkC's Avatar
ORIGINAL: Xman
Now... the Eibach Tech said also, that if the car has the shock connected to the lower A-arm that at the bottom of the a-arm where the shock is, is a bushing that is suppose to be tightened only when the car is set on the ground. I'm not quite sure how its connected at the moment. I'll have to look in the morning.
The bottom of the strut it not attached to the control arm.... but the rear control arm bushings could be bound-up the same way. You could try taking it back and asking them to loosen then retighten the bolts while the suspension is loaded.
Old Apr 24, 2008 | 07:12 PM
jag_genius's Avatar
totally different size of springs in front to back..
rvdz
Dec 7, 2019 06:42 AM
RaceDiagnostics
Dec 11, 2015 10:12 AM
jdzubas
Oct 4, 2015 09:14 AM
Fraser Mitchell
Oct 1, 2015 04:06 AM
Doug Dooren
Aug 30, 2015 01:40 PM
