stumbling, sputtering and dying on acceleration
Old Jul 31, 2008 | 09:10 AM
bluejaggg's Avatar
Default RE: stumbling, sputtering and dying on acceleration
it could be so much...
how many miles?
Old Jul 31, 2008 | 12:16 PM
Dennis's Avatar
ud
Did it HAve any mesages on the ODO screen?..Could be a vacuum leak
Old Jul 31, 2008 | 01:14 PM
bluejaggg's Avatar
Try to turn it on, and look for a check engine light. If it shows get the car to a shop who can tell you what code it is.
If you dont see the light on the ODO, pop the hood and listen, listen for vaccuum leaks, or weird clicking
could be an oil problem. try to replace the filter and see if that helps. when was ur last oil change?
make sure you have gas and ur guage isnt broken [sm=headbang.gif]
Old Aug 1, 2008 | 07:38 AM
Dennis's Avatar
ud
No such thing..But there is O ring that leak in the Throttle control valves that will cause the problem you described too..
jimforrest (uk)
Feb 28, 2019 06:42 PM
hkmcmast
Nov 29, 2015 06:56 AM
Poet
Oct 2, 2015 09:00 AM
n2audio
Oct 1, 2015 01:54 AM
