my x-type projects and installs
THIS THREAD HAS A LOT OF WRITE UPS ...THEY ARE
1-EASY TRANSFER CASE OIL CHANGE...thread#102
2-TRANSMISSION OIL CHANGE..thread #98
3-HID KIT INSTALL
4-DOUBLE DIN INSTALL
5-ILLUMATION FOR DECK WRITE UP
6- MY X-TYPE IS ALSO LOWERED
7- CHECK ENGINE LIGHT ...LIMP MODE REPAIR...thread #119
8- WIPER MOTOR FIX... POLLEN FILTER WRITE UP
IF YOU GUYS NEED HELP WITH ANYTHING LET ME NO
knew ..coming soon my fibre glass interior project
my grille
my hids
my dvd/navi
Hey Dennis....looks like some nice work you done there as far as I can see.
I've edited your post so that your pics can be seen ( try checking out the "how to" post pics in the Jaguar help n suggestion centre.
As you can see I haven't done all of them as there are a lot, sumthin you can possibly rectify at your leisure. It'd be great if you possibly did a write up on what you did and how you did it to accompany the pics.
Nice one
Jim
3-HID KIT INSTALL
my grille
my hids
my dvd/navi
Nice one
Jim
RE: my x-type projects and installs
Hi Dennis
Info on dvd Navi please How Much ? How difficult. Where did you buy it from? Write up would be great . Also what wheels are you running on the Jag. Brand type & Size? It looks sweet.
Info Info info.
john.
Info Info info.
john.
im starting a write up as we speak ...and aranging pics for this thread...i have a lot ,i also lowered the the car ill have it post asap
when it comes to my hid process ...the headlights were fairly easy now the fog lights i had to pop the bulb out put it in a vice then drill it out to fit the knew ones which needed the outer part of the housing...the dip beams i orderd from autolumination.com ..194s i got my hid kit from ebay 8000k iceburg blue ($71) i should have pics of install soon
use this wire for the illumination of your deck ...the orange wire from the nexxia adapter is for the dimmer and does not carry a full 12v
after painting
nexxia radio adapter
this is my first grille
my second grille
lowering springs
Received 9,005 Likes
Hey Dennis,
pics have't came thru. try reading the " how to post pics " in the Jaguar help n suggestion centre.
Jim
One would think a MOD or an almighty Admin would get off their pompass butts and edit his posts and put in the [img][/img] tags for him...but Noooooooo!
Oh sit back down Jim..I'm just kidding
after painting
my second grille
lowering springs
yaron369 (07-17-2012)
