Little Noise on XType2.0D
Old Jan 1, 2009 | 01:33 PM
BuckMR2's Avatar
Default RE: Little Noise on XType2.0D
Hi and welcome to the forum
The buzzing noise is probably the tiny fan which carries on running in humid conditions to circulate the air so you dont get blasted by warm air when using your climate control.It circulates air across the humidity sensor. It keeps running for a while after you switch off, and starts again when you open a door. It does this so that there is less delay in getting the climate control to the right setting when you switch on (or restart).
Old Jan 1, 2009 | 06:48 PM
jvegas's Avatar
mine does not make any noise, i had a loaner car that made a lot of noise. I would take it to the dealer and see what they can do. do you have a warranty?
JimC64
31
May 30, 2016 03:04 PM
inactualis
Oct 2, 2015 11:13 AM
baskervillema
Oct 1, 2015 06:43 PM
ChrisJay
Sep 27, 2015 09:08 AM
UKnFor-dluv-expat
Sep 26, 2015 08:40 PM
