Aux Input options?
The clear option for me was an FM modulator. This is not one of those cheap over the air signal things, it is a modulator kit that is hard wired into the stock headunits' antenna slot. Because almost all cars use a traditional antenna connection, this can be installed on almost all cars (including our X). It is actually a very easy install and the sound quality is superb. The sound quality is akin to that off a new cars' HD Radio. Plus it comes as a kit and you can place the on/off switch and AUX input in the glovebox or center console, or even add a dedicated iPhone/iPod connector that can even charge the device as you play!
This is the exact one I bought at Best Buy (they could even install it for ya):
iSimple IS31 Antenna Bypass FM Modulator for Factory or
![](http://i.seimg.net/images/432029/big/is31.jpg)
The following 2 users liked this post by aCapiz:
ChipReese (10-28-2015),
Thang Nguyen (11-16-2016)
You say the iSimple FM modulator gives good sound? I have a modulator and depending which iPod I use I get a loud hiss or a high pitch squeal. The clearest sound comes from my iPhone 4s, but all my music is on my iTouch, which keeps switching from charging to not charging. And every time it switches the music stops.
How much was the iSimple?
From the symptoms you are telling me, it sounds the device was wired to a bad ground This is probably why you get the hiss and squeal. Maybe the channel wasn't set to what it was on the little box that connects to the back of the head-unit (gives an option of 87.9 FM and another)? I do know that the smal over the air FM transmitters are pretty horrible sounding, but this device provides a quiet background and a good sound. My device was around $79, so considerable more than the over the ar transmitters but worth it IMO.
That's a very strange occurrence because mine does give a good sound and believe me I am an audiophile. I cannot have anything in my music library that is anything less than CD quality, and I can tell the difference between something like a 320 kbps mp3 with a 256 mp3.
You say it used a traditional antenna connection. I had to get some adaptors for mine as it used those fancy 'European' antenna connectors.
It's definitely an on going process!
Thanks for the info. I might buy the iSimple and see if the sound is any better. My FM modulator is a 'no name' one I found on ebay for around $40.
![Icon Doh](https://www.jaguarforums.com/forum/images/smilies/icon_doh.gif)
But yes, it will need the euro adapter thing to make it like a conventional antenna connection. I purchased mine at a small little car audio shop in my town for around $3.
Lcgi (11-27-2012)
I was wondering how you installed you Isimple? I am having trouble with the antenna part. Do I need a spliter to install the factory one and the one for the Isimple?
Thanks,
Mike
Hi I have just fitted the IS77 and it seems to be working great. I had to get a pair of adaptors for the aerial Fakra to din and din to Fakra (£10 from a local audio centre) I chose to use the 3.5mm jack plug input and located the unit behind the ashtray - I used the cigarette lighter for the power, mounted the power switch in the ash tray alongside the audio input.
Good luck
Good luck
Good luck
Good luck
i have just installed an IO Play 2 bluetooth music and phone system. it has an aux port and a ipod lead which i've placed in the glovebox. Its a nice powerful 160Watt system which sounds great and works exactly as you would expect.
with the Sounds on Top lead it came to £138 and took about 45 mins to install.
Sorry for the delay in answering have been away. I went away in the jag and was listening to music on my iPod and my daughter's iPhone through the IS77 and the sound was very good the bass is fine.
Andrew any chance of some pictures of your set up?
Zach
Zach
Hi all, just wondering on some mounting advice for the bluetooth model ISFM21. Where should I tap for power without hurting anything?
Also where should I mount the button??
And where should I run the additional Aux cable??
Just wanted to see your inputs and suggestions, thanks all!
