Jaguar Technician Information System (JTIS) download
Guest
Posts: n/a
Basically the factory service manual in a computer program... has most diagrams you would need to diagnose anything with the car as well as system faults...
I found it here: http://www.cannell.co.uk/Jaguar_Work...uals/JCD-1.zip
You can download it, install it with 'setup.exe" (doesn't appear to run on vista though..). Once installed you select your vehicle type and year (only has up to 2003, but has XJ Range, XK Range, s-type, x-type and XJS.
hope this helps somebody as it sure helped me! ( I didn't even get the manual with my car ;\ )
The following 11 users liked this post by :
DB28704 (07-23-2016),
JagPiglet (12-01-2017),
James King (02-21-2016),
jeff16 (06-20-2016),
kiyana (07-27-2015),
and 6 others liked this post.
Received 9,010 Likes
The following 2 users liked this post by JimC64:
Eureka1 (04-18-2015),
isaacfornari (03-07-2016)
Guest
Posts: n/a
RE: Jaguar Technician Information System (JTIS) download
Have not tried it yet but know Vista will allow you to set a program to run in compatability mode. Which means you should be able to set it to simulate the native operating system. Do not know if this will work, can give it a shot later in the evening & let you know.
JMan
JMan
xp = x32 bit &x64 bit O/S.
Vista = x32 & x64 bit O/S.
So this shouldn't matter.
but when installing under vista try this.
1.) right click on the installation file (i.e setup.exe)
2.) select properties
3.) click on compatibility tab
4.) under compatibility mode make sure to check the box that says "run this program in compatibility mode for:"
-this will enable the drop down list then select. XP service pack 2.
This also works with other program that you might want to migrate to Vista
hope that work
hope that work
