How I Feel Looking at the V12....
The following 4 users liked this post by Some Day, Some Day:
orangeblossom (01-19-2017)
Sure, no problem. Here it is.
Taken with my 8-16 mm ultrawide lens using a Canon 60D. The ultrawide is very sensitive to any missed verticals, and I was holding it with my arm stretched over the engine, so it's not quite straight unfortunately.
Daim: Yeah, there's definitely a lot of that in there. Though when I first saw the engine, there was also a definite aspect of something like the Grand Canyon - awesome, vast, ancient, and deep....
My first impression was similar. Add to the visual the knowledge that it was not running, and that I was going to buy it...
Like scene from Indiana Jones. Looking down into a cobra pit with a beautiful red jewel barely visible at the bottom. And I was going to try to take it!
My first goal was to make it run, then to make it run well, and then to make that V12 look like it was being served up at a posh restaurant. An all-aluminum morsel gleaming in the middle a glossy red plate.
Its not there yet, but I can see it coming as I peel off layers of grime, government hoses, unnecessary baubles and electrical chains. It will gleam.
The following 4 users liked this post by JigJag:
The old V12 Jaguar XJS joke was, apparently, about the factory quality control component completeness test. A large bottle of water was poured over each V12 installation, bonnet open. If any came out of the bottom of the car it had to go back on the line to have the missing parts fitted.
Greg
Greg
The following 5 users liked this post by Greg in France:
BC XJS (01-13-2017),
Daim (01-13-2017),
dborthwick (01-13-2017),
orangeblossom (01-19-2017),
Some Day, Some Day (01-13-2017)
The following 2 users liked this post by BC XJS:
Daim (01-13-2017),
The following 2 users liked this post by Jagboi64:
Doug (01-14-2017),
Your engine is an interesting hybrid between the earlier 5.3's and the later 6.0's. You have the intake manifolds with the logo, the cruise actuator like a 6.0, but the older 5.3 style AC compressor and air filter boxes.
Some things are different to what I'm used to, like the absence of the fuel cooler on the suction side AC hose. There are a couple of electrical components that I have not seen before either, obviously market/ emission spec specific.
Beautiful photography, and a very well done Photoshop.
That about says it all, at least for me.
Once you start to understand what's-what and how it works (very time consuming), it is actually bloody simple, just a lot.
The following 2 users liked this post by ericjansen:
Interesting. Quite likely true. Which ones did you notice? Japan has some pretty strict emissions testing, so I assume they're there for that.
1. Having to remove several things to get at anything else.
2. Twelve of everything
3. Cramped spaces (related to 1. above)
The engine itself is apparently very old-school simple. I'm still learning just what is what, however.
Your air injection check valve (right side of the engine, next to the fuel rail, just forward of the polished crossover tube) is in a much easier to get to place than mine! I have 2, at the back of the engine and partially buried. They are GM parts, so cheap here.
Although one of the joys is practically everything is on top. Once you get below the intake manifolds there is almost nothing there except the exhaust pipes.
Doug (01-14-2017),
That's interesting. Two of those different things seem to be connected to air quality and thus, one assumes, emissions - the air box wires are presumably some sort of sensor. No idea what the red/orange thing is. I'll take a closer look next time I have the bonnet up to see where they go.
Nice to know that not too much is buried in the bowels. What I would really like, and haven't seen even in Haynes or the ROM (unless I missed it) is a diagram of the engine showing what is what. Mind you, it might get excessively complex....
