Alloy wheel Silver Touch Up paint arrived today
Jaguar produced many variations of wheels for the XK/XKR. Not all were the silver painted wheels as shown above. Some had painted spokes as seen on the 2009 Jaguar XKR's with the Selena wheels. There was a chrome piece on the wheels as well as paint that came close to matching the body color.
If any part of your jaguar wheel was painted, you would need the proper paint code other than the silver mentioned above.
Click the image to enlarge.
Most, probably all, wheels are produced by a number of European manufacturers who use a surprisingly wide variety of colours and finishes. As a rule, they do not publish their formulae/paint codes. Wheel refurbishers and paint suppliers on the internet have some very close matches! I have received useful advice on a number of occasions from www.alloypaints.com with whom I have no association, usually through eBay's ask a question service responding to their: Alloy wheel paint aerosol pick your own colour 400 ml
listing.
I have successfully refurbished quite a number of our own Jaguar wheels and am happy to tell you what paint I used if you let me know your wheel name. I can probably identify it if you do not know and attach a picture.
Mike.
listing.
Mike.
MarkyUK (07-06-2019)
Received 1,967 Likes
I have had both these but not refurbed them.
Have a look at them in the sun. If there is a noticeable medium sparkle in them go for Silver Dollar from Wheel Paints. I appreciate this may be difficult in The States but you can probably get something similar. I use Simoniz wheel silver as a base for all wheels with nothing more sparkly over the top for wheels with only small flake giving a slight sparkle and that might be fine for your Carelias. I have no spray gear and get pretty good results. Most wheels only need curbing attending to filling with Holts putty, sanding and spraying the circumference having elevated a card circle, with a diameter about 2cm less than the wheel, about 5mm above the rim to allow the silver to feather in. Best to spray the lacquer on a warm day and dry in your X Type Estate in the sun! See also my post about fake wheel bolts although I believe those on the Senta screw out.
Hope this helps.
Mike.
Hope this helps.
Mike.
was it curb rash or a few scratches?
Paint, like anything comes in lots so I was wondering how it matched/ blended.
Local vendor here charges $155 a wheel and they remove the tire. The car I bought came with some curb rash and I hate body work (sanding). I'd like to understand the effort you made before deciding how I move forward.
Time isn't money to me as I'm retired so I'm not including my hours as cost.
So if you don't mind, what did you repair and how'd it turn out?
Thanks in advance.
listing.
Mike.
listing.
Mike.
Old post I realize, but wanted to ask suggestion for paint to refinish Jaguar polaris wheel?
19" wheel, from 2009 XJ8 L (X358).
Thank you.
-Kaboom
Yes, get back to me have copied this from above to ensure you have seen it. Have a look at them in the sun. If there is a noticeable medium sparkle in them go for Silver Dollar from Wheel Paints (on ebay)www.alloypaints.com with whom I have no association, usually through eBay's ask a question service responding to their: Alloy wheel paint aerosol pick your own colour 400 ml
listing. I appreciate this may be difficult in The States but you can probably get something similar. I use Simoniz wheel silver as a base for all wheels with nothing more sparkly over the top for wheels with only small flake giving a slight sparkle and that might be fine for yours. I have no spray gear and get pretty good results. Most wheels only need curbing attending to filling with Holts putty (fine filler self curing), sanding and spraying the circumference having elevated a card circle, with a diameter about 2cm less than the wheel, about 5mm above the rim to allow the silver to feather in. Best to spray the lacquer on a warm day and dry in your X Type Estate in the sun!
I purchased the alloy wheel silver touch-up paint pencil (5173) with the companion clear lacquer from my dealership (after they first verified the vehicle; it was the last set they had in stock); C2A1237; I just posted a thread inquiring if anyone had used the product and what was their impression with the results.
Daneel227 (07-10-2019)
FS[SouthEast]: Jaguar v12 xjs convertible 44,000 miles
revitup
09-21-2016 04:51 PM
tomas6791
XE ( X760 )
09-17-2016 11:47 AM
