Detroit Wheel problem
My damaged rear Detroit wheel is becoming a nightmare as the BMW dealer I left it at has tried to get a new wheel from Jag and a matching silver one is apparently not available. He ordered a new one, it came and was the wrong color. I just thought I would ask for any help here that might be available.
OM;
Didn't you start a similar thread a while back?
I was afraid of this.
Try John at itelgroup@gmail.com
Or
Steve
SB Wheels
Jaguar Alloy Wheels T: +44(0)7891 376 829
E: sales@sbwheels.co.uk
W: www.sbwheels.co.uk
There is also this listing on ebay for an exchange of refurbished wheels.
jaguar detroit alloy wheel | eBay
They all source new and refurb wheels, though I know from experience finding silver Detroit's is getting to be tough.
I would check with Steve first since he ships to the US all the time and mention you chatted with me....he won't hold it against you too much. He is also the go to guy for Original Center Wheel Cap Medallions for a good price.
As for not being available from the Dealer here is what Steve wrote me about it last month.
Hi James, to answer your question it is true. The older model division of BBS have been in admistration for over a year now and sopurcing wheels and parts is harder, infact some of the BBS parts/wheels are no longer obtainable direct from BBS.
There have been no older model Jaguar BBS wheels produced for sometime now and all of these are getting harder to source. I have large quantities of the air adaptors, valve assemblies, titanium studs etc in stock (all brand new) as well as the replacement stainless trims that we manufacture, so we will continue to supply these without any difficulty but new wheels and sets are harder to source. I have large quantities of brand new 20inch and 18inch BBS wheels, but these are now coming more irregularly than they used to. Hope this clarifies for you, Regards, Steve
One last note....I have read some pretty bad stories about refurbished wheels being badly done and hiding problems behind the attachment bolts, ie glued on heads instead of threaded, etc.....so unless you get a guarantee with it I would steer away from them.
good luck and let us know what happens,
cheers,
jj
Or
Steve
SB Wheels
cheers,
jj
Well, the rebuilder coudn't fix the wheel, so I ordered one from a wheel company in NJ that had one on ebay. they seemed like a good company when I talekd to them so we'll see soon. I hope it fills the bill. I still would have liked a new one, even at $2,000. When I get my old wheel back, I'll look into trying to get it repaired myself, even if it takes a lot of work. there are some rebuilders that are better than others, just a matter of finding them. Scott (one of the Jag reps) at Coventry West says they have a rebuilder in Atlanta that has never failed to repair a wheel, and Coventry can install the new trim rings themselves.
Well, the rebuilt wheel I got on Ebay turned out to be very nice and it looks new, with new bolts, trim ring and air valve. $750 plus shipping. I am back on the road after more than a month. My old wheel looks rebuildable to me, so I am going to attmpt to get it repaired since these wheels are getting very hard to find, I may need it some day. I plan to send it to Coventry West and see what they can do with it. I did find that these 20" BBS wheels are steel! Only the mounting spider is alloy. This should make them easier to repair as steel is more malleable than cast alloy.
I had a rear Detroit refurbished by a company here in Edinburgh about a year ago but recently I’ve noticed a creak from the wheel at very low speeds which turns into a fast clicking as the speed increases and eventually can’t be heard at higher speeds. Has anyone come across that noise before and had any idea what it could be?
I wondered if the refurbisher could have sheared one of the bolts when dismantling the wheels and simply glued it back on. Could that be the cause of the noise?
Thanks!
Thanks!
The sound is certainly amplified in enclosed spaces but it's audible most of the time driving at normal speeds. I've even had colleagues at work comment on the noise coming from my car.
Thanks for that. I hadn't considered the possibility that the alloy wheel was cracked. I'll get it checked out tomorrow.
The good news is the problem has been solved and the noise has gone. The bad news is I still have no idea what was causing it! The squeaking wheel was inspected and found to be in perfect order so I asked for the left and right rear wheels to be swapped over. The noise immediately disappeared. I suspect there are some slight differences in the two wheels and whatever they are allows them to run more freely in their new wheel arches. The tyres are Pirelli P Zeros which I believe are multi-directional so the wheels should be fine on the opposite sides.
As written by Oldmots
Shortly after purchasing my XKR I decided to buy a used set of Detroits knowing that they were discontinued (HyperSilver) I was surprised that the Oyster was still available. I suspect many of the Optioned wheels, because of low manufactured numbers won't be available in the near future. If anyone is planning on keeping their cat for a long time might consider purchasing another set.
