1989 Stereo Replacement
Guest
Posts: n/a
I recently purchased a 1989 Jaguar XJ6 and the radio wasn't working when I bought the car. I currently have a stereo with a 7inch fold out monitor and built in DVD monitor installed in my Saab Turbo that I will be selling soon and want to use the stereo in the Jag. I know that I will have to put the car in gear in order to open and close the screen due to clearance issues with the shifter, but are there any other concerns that I should be aware of. Also is anyone aware of a wiring diagram for the stereo, I found a link through a google search but it is dead. Any help would be greatly appreciated. ![Wink](https://www.jaguarforums.com/forum/images/smilies/wink.gif)
Chris James
Phila,PA
1989 Jaguar XJ6
Chris James
Phila,PA
1989 Jaguar XJ6
Guest
Posts: n/a
This is the best I could find:
1989 Jaguar XJS Car Stereo Installation Diagram
Car Radio Battery Constant 12v+ Wire: Brown/White
Car Radio Accessory Switched 12v+ Wire: Green/Orange
Car Radio Ground Wire: Black
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Green
Left Front Speaker Negative Wire (-): Red/White
Right Front Speaker Positive Wire (+): Red/Green
Right Front Speaker Negative Wire (-): Pink/White
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Red/Brown
Left Rear Speaker Negative Wire (-): Red/Green
Right Rear Speaker Positive Wire (+): Pink/Yellow
Right Rear Speaker Negative Wire (-): Pink/Green
KarimPA
09-12-2015 08:15 AM
