2003 Jaguar S-Type Car Stereo Wiring Schematic
The EX-10 does offer a hardwire option as well as FM modulation. It has a 1/8" stereo plug output, and will also stream A2P stereo music off the blackberry including pandora or slacker radio.
I know the bt interface isnt the greatest, but personally I just use my phone to dial no matter what bt solution I have. I'm not going to scroll through the phonebook on the dash.
Let me look as the older threads.
I wish there was a better way to organize files with the ACM. Esp on cars with a nav screen. Portable hard drives are REAL cheap these days, as are 32gb flash drives. But there's no way to organize a music collection in much of a useable form on them when all you get is disc and track number.
EDIT: Ok I looked at those soundgate devices, they are simply fm modulators. Nothing More. The only hardwired way into the head unit is the ACM. Unless I can cook something up to be used with an external player.
Let me look at the schematics again...
EDIT: Ok final edit. IF you want an aux in into the radio, without opening the radio, you NEED the ACM. Not only is the CD changer completely Opitcal fiber, but so is the connection between the radio and the amp. It's really a case of gut it all or keep it all. There is no audio output used from the head unit even.
No wonder the ACM costs as much as it does, considering it's got a bunch of A/D converters in it, besides the rest of the hardware.
George
George
I found this on the net. Is this correct?
Car Radio Battery Constant 12v+ Wire: Green/Black
Car Radio Accessory Switched 12v+ Wire: Black/Pink
Car Radio Ground Wire: Black/Green
Left Front Speaker Positive Wire (+): Orange/Green
Left Front Speaker Negative Wire (-): Blue/White
Right Front Speaker Positive Wire (+): Tan/Green
Right Front Speaker Negative Wire (-): Green/Orange
Left Rear Speaker Positive Wire (+): Gray/Blue
Left Rear Speaker Negative Wire (-): Brown/Yellow
Right Rear Speaker Positive Wire (+): Black/Violet
Right Rear Speaker Negative Wire (-): Orange/Violet
http://www.modifiedlife.com/2003-jag...ing-schematic/
Since I couldn't find any wiring harness, I'll be cutting the wires and connect them directly to stereo harness.
Thanks,
Thanks,
LFront (-): Yellow/Black
LFront (+): White/Black
RFront (-): Yellow/Red
RFront (+): White/Red
LRear (-): Yellow
LRear (+): White/Blue
RRear (-): Yellow
RRear (+): White
I don't know how far you boys got with checking wheather the above speaker wiring colours were correct from this site but for my Aussie delivered STR, and I assume most of the S range, they are as follows for anyone who needs them.........
LRear (-): Yellow
RRear (-): Yellow
RRear (+): White
LRear (-): Yellow
RRear (-): Yellow
RRear (+): White
i agree with the above
-Related to this topic:
I hooked up my amps using High level input. I ran the wires through the along with the rear speaker cables straight into the doors and hooked the Amp's input cables straight to the factory speakers. It is easier that to take out the whole deck and ru the wires all the way to the front; However, and this is my question:
IS THERE A WAY TO HOOK UP THE REMOTE WIRE(AMP TRIGGER) SOMEWHERE IN THE BACk? I was thinking of the CD Changer which should have a remote(trigger wire). But I can't find an electrical Diagram for the CD Changer, nor the wire configuration. Does anyone have that diagram? Or Does anyone have another solution for this issue?
PLEASE HELP!
PLEASE HELP!
#28
Here are downloadable electrical reference volumes for every Jag of interest - don't get intimidated by them, theres a LOT of information. The diagrams for the Entertainment systems are all towards the end.
http://www.captainjaguarscathouse.co..._Reference.htm
From this diagram, it appears as if the 03 S type uses fiber optic for passing audio signals from one unit to another.
![Icon Doh](https://www.jaguarforums.com/forum/images/smilies/icon_doh.gif)
Is there a harness out there for us or am I going to have to hardwire my new stereo?
#30
#32
#34
If anyone is still looking at this thread, I could use some help.
In my 07STR, i have taken out the carpet in trunk. Can see the battery, fuse box, and the cd changer and amp setup. I have the premium alpine with nav system of course.
I wanted to try an experiment, wondered if it is possible to grab the sub out wires coming out of the amp and try to run them to my boxed subs instead?? which wires coming out of the amp would the sub wires be? there seems to be 2 thicker wires coming out of the amp and i thought those could be for the sub??
if the stock amp does not do a good job powering the aftermarket subs, I was then going to install my aftermarket amp in the trunk. I was thinking I could just run power and ground to the amp from the battery and chassis there in the trunk easy enough, but then WHICH WIRES coming out of the stock amp would be good to use for high level inputs into the new amp? is it possible to run the stock sub wires coming out of the amp over to my other amp as low level inputs?? or should i grab a door speaker wire coming out of the stock amp and run it to the new amp as high level inputs?? please help me understand which wires are coming out of the back of the stock amp thanks
#35
fyi, the stock amp did not do a good job powering dual 10 inch subs, so i ran wires from the stock amp sub out lines to the inputs of a new amp, hooked up thr amp to battery and chassis, and set the amp to power on when audio signal is received thus no need for remote turn on wire.. and wow it sounds awesome.. no problems with stock amp and stock subs they are still working just fine. i think i tapped into the stock sub out wires from the stock amp.. and ran those into the new amp, i do not hear a difference when selecting high or low input level on the new amp, so i left it at high level input, seems to work just fine.
#36
#37
msdg137
09-16-2015 06:24 AM
Terrance Williams
08-26-2015 11:50 AM
NinoGrimace
08-26-2015 05:15 AM
