Adding 4 channel amplifier
1998 Jaguar XJ8 (stock system, not premium speakers).
I was hoping someone with audio experience could assist me with an audio install I am thinking of doing.
What I would like to do is install a 4 channel amplifier to the stock head unit. I am thinking of running two speakers lines from the trunk (where the amp and 4 channel line converter will be) to each of the existing speaker locations. One speaker line will be for the running the new component speakers to amplifier.
What I am wondering is can I take that second speaker line that runs form the trunk (off the line converter) and hook that up to the existing 6.5" driver speaker cable (note: I will not be using the old drivers rather use the old driver speaker cable as a source of signal to the new speakers). To make things easier I plan on using this wiring harness so I don't have to cut any wires.
Speaker Harnesses Speaker adapter plugs for select 1989-up Jaguar, Porsche, Saturn, VW, and Volvo at Crutchfield.com
If I understand correctly the only crossover in the stock system is located on the tweeter. I know most people say to wire right off the back of the head unit, but would rather go directly off the old speaker lines (when I say speaker lines I mean the 6.5" driver lines directly to the line converter
Sorry if this sound confusing as i was unable to upload a image of what I am thinking of doing).
Any help would be greatly appreciated.
Jaguar Forums Editor
Jaguar Press release
09-28-2015 05:18 PM
FS[MidAtlantic]: 1997 XJ6 VDP $3,900 - Very RARE Anthracite on Warm Charcoal
42Ajd
09-26-2015 07:04 PM
