Amp for Rockford Subs
Hey guys.
Still deciding what to get. Either two 12" Rockford Fosgate P2L's (rated at 500w RMS x 1 CH @ 4ohms) or the single 12" Rockford Fosgate P3L (rated at 500w RMS x 1CH @ 4ohms).
I was leaning towards the single P3L and a Pioneer amp that pushes 400w RMS @ 4ohms. I would rather the sub be a little underpowered to increase it's longevity, correct?
The other option would be having two 12" P1L's rated at 300w RMS to go with a Rockford amp that pushes 320w RMS @ 4ohms.
What do you think? Thanks.
Hi wesside, It sounds like you are a real Rockford fan.
I personally have used their amps and subs myself. Though their amps are top notch, and like them along side many other brands, their subs to me just didn't match up. I know that is totally personal opinion, but if your not stuck on using the Rockfords, I can however, recommend a single 10" or 12" JL Audio w6 model, i haven't found anything that can match it yet. I can't give any opinion on the Pioneer amp, unfortunately.
I do agree to put a larger amp in there than your sub is rated, and have some power left over.
We do have a couple audio experts on here, so hopefully they'll see your post and give you some additional advice with a more broad experience in equipment and how to set them up
And I'm 90% dead set on the Rockford subs. This year's model comes with the subs pre-enclosed and the vented enclosure is just awesome, yes?
Thanks for the reply.
I'm kind of the same way however I can't seem to find an RF amp that can power these. The only one I saw was like $599 on amazon.
