Bluetooth Install - Veffremov's Kit
#102
#103
#105
I received this email from the maker of the device as of today no updates on when will be available.
Sent: Saturday, September 10, 2016 2:44 PM
Production is halted temporarily. I'll send you an e-mail once I have a unit available for you.
Andy Myvegas Taylor (10-21-2016)
#107
Andy, there is a waiting list and I build devices and offer them to the people on the list on a first come first serve basis.
By the time I have a device ready some people change their minds, and the device goes to the next person on the list.
There is no steady production of these units. It is a weekend job for me and sometimes life takes precedence.
The following 4 users liked this post by veffremov:
Andy Myvegas Taylor (10-21-2016),
Brian M Williams (06-01-2019),
Lagonia (10-21-2016),
LoganR (10-22-2016)
#108
Your da man V. I have not ridden my X350 for about a year now but every time I get in the car to move it around the shop, it dutifully connects to my iphone with ease. Once I do a suspension rebuild and a timing chain cover gasket replacement to combat a leak over the Christmas holiday, I shall promote it, once again, to daily driver status and shall again be enjoying my bluetooth streaming using your device.
#109
Many thanks for posting.. I definitely want one of these units please. Could you put me on the list please?
I can send you a deposit if you wish.
Regards
Andy
#111
Hello everyone. I've had one of these kits installed for about a year, and it's been great. I honestly don't think I've ever had a signal dropout, up until recently.
The last couple of months however, I've had an annoying issue, where my iPhone will not pair with the bluetooth automatically when I start the car. I have to go into my BT settings in the iPhone and connect manually. After that, sometimes it works fine, and sometimes it'll drop the connection a few times and cause me to manually keep reconnecting.
I'm trying to figure out if this is an issue with the "Veffremov Box" or if it's an issue with my phone. I'm on an iPhone 7 Plus, but the issue started prior to this phone, when I was still on a 6. It could be iOS 10, but I'm unsure of that.
I haven't tried resetting the box at all because I wouldn't know how to go about that, but I'm open to suggestions from anyone here. Thanks in advance!
Justin
Justin
#112
Best to e-mail me jaguarbluetoothaudio at gmail.com. Looks like an issue with your unit.
~Veffremov
#115
Did the install yesterday. Great bit of Kit !
Took me about 20min do to see. Just get
the clips of the carpet away. Before you take the CD changer
out make life easy and if you have the DVD drive on top remove that
first for easy access to the rear cables of the CD changer.
Didnt except the soundquality to be that good.
Top notch service venelin
#116
the only problem I find with this is that it seems to default to a previous playlist even when you change it to a newer one using a different app.
Example, using a playlist in poweramp. get out of car, open music playlist in google music expecting that to play, but it continues playing the poweramp playlist, its as if it tries to cache the lot then fails to change to what you are wanting to play, using a galaxy S8
#117
Bluetooth Audio Update for Jaguar Cars
I thought I could get by without updating the audio system in my car, but my pre-teen son kept saying how his mom's car was better than mine because she had a better audio system (only item he thought was better). I finally decided to try Veffremov's Bluetooth Audio Update and have placed an order. I have been following this topic for a couple of years, not only on this forum but other avenues as well. I could not find anything that didn't require a new video screen, expensive after market systems and or complicated modifications. Based on all of the positive post I have seen on this formum and Veffremov's support of his system I have no doubt I will be completely satisfied. I will keep you posted once I get the system and it is installed. I understand it may take a while to get it, but I think it will be worth the wait.
#120
