Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. let's hear about it here.
Bluetooth Install - Veffremov's Kit
Old 11-16-2017, 08:57 PM
veffremov's Avatar
Try re-starting the bluetooth on the iPhone. Turn the bluetooth off, wait a bit then turn it back on.
  #122
Old 11-17-2017, 08:49 AM
tmalves's Avatar
thanks!
after one night sleep it worked!
  #123
Old 11-18-2017, 02:21 PM
Torque's Avatar
Originally Posted by veffremov
I'm taking a haiatus from this task. I may start making some more next year.
any chance you would be willing to make this an open source project and share your schematics, parts list, and applicable coding?
  #124
Old 11-26-2017, 04:08 AM
SailorSam's Avatar
Good morning,
When you do, if you do, I want one!
Can I register somewhere?
Thanks,
Mark B.
  #125
Old 12-06-2017, 04:17 PM
kandrysiak's Avatar
I want one too waiting for it
  #126
Old 12-28-2017, 02:38 AM
veffremov's Avatar
Here is the schematics of the D2B board. https://goo.gl/zBroxo
The other component is a Raspberry Pi. In the older versions I used A+ models, in the newer ones I use Pi Zero.
Here are instructions how to re-build the software for the Pi, for the enthusiasts: https://goo.gl/sK8ZBV
misiek93 (03-29-2018)
  #127
Old 01-05-2018, 09:17 AM
Default updates?
Veffremov any update on these? I really want one for my car and don’t want to break the bank with a whole new system since I got alpine and nav, I’ve got an s type R.
  #128
Old 02-10-2018, 03:59 AM
MattK's Avatar
I would like to order one. Is it still available anywhere? I couldn't find it.
  #129
Old 05-02-2018, 03:55 AM
AfricanJag's Avatar
Hi @Vreffmov I am also interested in this!
  #130
Old 07-13-2021, 01:20 AM
DSV8's Avatar
Cool Wow - this looks amazing
@trosty the kit should have 2 USB cables one long (6ft) and one short(1ft), connect the short cable to the device then the long cable to the short one, finally the end of the long cable is connected to the USB dongle and that is mounted on the rear shelf close to the speakers.
Route the USB cables so you will have easy access where the short cable connects with the long cable. To perform SW update disconnect the long cable from the short cable and plug a USB stick.
I personally let the two USB cable junction hang from the stack and behind the door for easy access. See pic.
Are these kits still available to buy? I've been looking for a solution to get streaming to my X358 for the last three years and haven't come across anything that seems quite so elegant a solution
  #131
Old 07-13-2021, 05:29 AM
Marque's Avatar
Unfortunately they are not. You could check to see if someone may be selling there's, or look up "JagDroid" which is quite a bit more in cost, but really modernized for our cars...
DSV8 (07-13-2021)
  #132
Old 07-13-2021, 05:05 PM
DSV8's Avatar
Awesome - thanks for this info. I think you've just given me a project for my next holiday..... and emptied my wallet somewhat. However, as you say, it looks like the JagDroid systrem will completely modernise the experience.
  #133
Old 07-20-2021, 03:46 AM
mrvip's Avatar
I have the veffremov's module, but forgot how to reset the paired devices list, which if I remember correctly has only 5 slots and now can't pair another device. It was supposed to be done through a sequence of selecting "disks" on the cd changer interface. If anyone has the details, I will highly appreciate it!
  #134
Old 07-20-2021, 04:22 AM
mrvip's Avatar
After some digging in the source code, I found it myself The sequence is 534.
  #135
Old 10-09-2021, 03:03 PM
Brian M Williams's Avatar
Do you have any of these for sale? God I hope you do. Thanks, Brian
  #136
Old 11-21-2021, 04:14 PM
Does anyone have one of these for sale by any chance? Thanks.
  #137
Old 11-22-2021, 07:30 PM
ControlIssues's Avatar
Could you elaborate on this procedure? Pretty sure I'll need to to do this for my next phone.
Love this streamer. Its great.
Thanks.
kosta013
12-06-2019 10:27 AM
Dz1rfj
07-17-2018 10:29 AM
Dz1rfj
09-16-2015 03:44 PM
veffremov
09-09-2015 01:23 AM
carelm
09-05-2015 01:13 AM
Quick Reply: Bluetooth Install - Veffremov's Kit
