Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. let's hear about it here.
Bluetooth setup problem - RESOLVED
Old 03-16-2013 | 10:04 PM
Unshriven's Avatar
Default Bluetooth setup problem - RESOLVED
I have to remove a phone on my XJ8 (2005). When I press the phone icon, instead of showing "SIG" it shows "HANDSET" so I can't remove the old phone, I was wondering what I was doing wrong. I couldn't find an answer here or in the manual.
Last edited by GGG; 03-26-2013 at 09:44 AM. Reason: Add 'RESOLVED' to thread title
Old 03-17-2013 | 08:27 PM
When the ignition is switched ON, the BT system searches for the last paired phone. If the phone is not found, then HANDSET is displayed.
If all you want to do is pair another phone, enter ##3#*# and press SEND to initiate the pairing process. At this stage, go through the DISCOVER procedure and this will overwrite the old paired phone.
Old 03-17-2013 | 08:44 PM
Unshriven's Avatar
I tried that and every time I get to the number 3 it goes to my third preset radio station
Old 03-18-2013 | 05:55 AM
If button 3 is responding as a pre-set, the system has dropped out of phone mode and back into audio mode.
You have 2 minutes after switching on the ignition either to switch on the previously paired phone or enter ##3#*# and press SEND to initiate SIG mode. If neither of these are done within two minutes, the system reverts to HANDSET and drops out of phone mode.
I swap between two phones regularly but have only once had an issue with the system locking up. A hard reset fixed this.
Old 03-25-2013 | 11:38 AM
Unshriven's Avatar
Just wanted to let you know this worked. Thanks for the clarification.
GGG (03-26-2013)
Old 03-26-2013 | 09:43 AM
Thanks for confirming the resolution.
I've added 'RESOLVED' to your thread title to help anyone looking for the answer to this issue in future.
Forcedair1
05-14-2023 04:28 PM
Dz1rfj
07-17-2018 11:29 AM
FrickenJag
09-25-2016 09:00 PM
carelm
09-05-2015 02:13 AM
mhamilton
US Lower Atlantic
09-04-2015 06:00 PM
Quick Reply: Bluetooth setup problem - RESOLVED
