CD Changer reporting NO DISCS?
CD Changer reporting NO DISCS? - FIXED
My X-type 2004 estate was playing cd's from the multichanger when it just switched to radio? When i pressed CDC the screen came back with the message NO DISCS.
I have removed the cd cassette to check discs are ok and re-inserted, this time the CDC display came on and then as it tried to play a disc it repeated the previous message.
Im going to try a cd lens cleaner to see if that sorts it but are there any known faults? such as its knackered?
Kind Regards,
Steve...
i took the discs out and inserted a lens cleaning cd with some fluid on and it picked it up and played it fine, re-inserted the cds and they also play fine. I think it could have had a problem grabbing one one the cds from the tray and caused the error message. All ok and working at present.
Steve...
Kind Regards,
Steve...
Steve...
I just went through this with my 2004 XK8. I bought it with the same problem. I took the unit out, and apart. Used a long reach swab with some rubbing alchohol on it to clean the "eye." If that doesn't work, generally the "eye" has gotten out of alignment, and time to search eBay for a replacement. In your case the cleaning disc did the same thing. If it persists, try the swab technique on a more stubborn problem. Sometimes you get lucky! MC
Finbarr1975
09-16-2023 02:52 PM
