Connect iPod to cassette audio out on XJ8
I have a 2001 with the Alpine system and would like to get the best sound from my iPod. I am using a cassette adapter for my iPod currently but the dynamic range still sounds far short of the CD player.
Can I tap into the audio out connections from the cassette deck to the head unit and connect a jack? I would still insert the casette adapter into the deck but would not use the audio connection so the tape head would not recieve any signal
Any advice is appreciated, thanks
Your best bet is to use a slightly modified PIE AI_AUX adapter with a PAC LD-10 preamp as described in this thread: https://www.jaguarforums.com/forum/x...e-32776/page4/
Total cost is under $100 plus some time.
On an '01 XKR, the stock PIE unit can plug between the nav. unit and the premium audio power amp and not need to be modified at all. I think your VDP SC may be similar, but am not 100% certain. If it does not work, you would need to do the circuit board mod. to the PIE described in the link.
The information you posted on the cassette mod is very useful..thank you.
Just to clarify, however, the PIE AI-AUX method does not impair the functionality of the CD changer.
thanks for the replys guys..
WhiteXKR - does the Pie unit have to be rewired? I wasn'tclear if it ws needed or the Pie had to plug into the NAV instead of the CD changer?
Jochemoo - do you know if the ouput (Impedence?) of the iPod is correct to feed directly into the head unit?
thanks
thanks
Does this need a tape playing in the player for it to work?
Take care,
George
42Ajd
12-30-2015 09:45 AM
FS[MidAtlantic]: 1997 XJ6 VDP - Very RARE Black on Black
42Ajd
09-21-2015 07:37 PM
