Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. let's hear about it here.
Inside a jag radio
Old 07-17-2009 | 12:07 AM
veffremov's Avatar
Default Inside a jag radio
I got a CD/Radio unit from a late model S-Type and decided to peek inside. A few photos of the effort:
http://cid-929c26e96a635de1.skydrive...%20Jag%20Radio
The main CPU is Fujitsu MB90F574/A flash based 16 bit microcontroller. The audio DSP is SAA77064. The tuner frontend is SAA6588TV. The optical unit is made by Apline.
The D2B interface IC is a mystery has label 2440 OS8101. I could not find any documentation about it, except it is also used in some Benz units. Supposedly ST micro still manufactures the clip, but has no info whatsoever.
I'll try to peek in the CPU software to see if I can learn more about the D2B bus.
Old 07-18-2009 | 11:49 PM
FloridaJag's Avatar
Nice job. Gives the appreciation for what goes into these radios.
Old 07-23-2009 | 03:50 PM
super_jag's Avatar
I opened mine up as well, but it was to change the leds.
Old 09-10-2009 | 06:52 AM
ecol2's Avatar
does the early s type have changeable LEDs
Old 09-13-2009 | 06:52 PM
veffremov's Avatar
Depends, what you mean by changeable. Defenitely there are no sockets, you need a soldering iron to remove the old ones and sloder new ones in place.
philwarner
10-04-2024 02:37 PM
Dz1rfj
07-17-2018 11:29 AM
cissdm
05-03-2016 07:02 AM
Dz1rfj
09-16-2015 04:44 PM
Numwen
09-06-2015 01:30 AM
