Navigation Is Lost?
Is there some way to "calibrate" the nav system in my 00' XJR? I tried to use it the other day for the first time (new-to-me car) and it was way off on directions. I understand that the map is outdated, but it wasn't even close on streets that are older than I am. Any suggestions?
Wasn't me but I think it may have been someone else who had been installing the pressure check valve for the convertible pump. If you search through threads on the XK8/XKR forum regarding the convertible hydraulic hoses/relief valve you should find that guy's post.
Doug
SoCalJagS
09-27-2015 09:20 AM
