No sound from premium Alphine stereo??
Guest
Posts: n/a
Received 3,887 Likes
Rodneyat, check fuse F26 (30 amp fuse) in the rear power distribution box. That is the fuse for the amplifier. But, if that fuse is good, then you are more than likely looking at a failed amplifier. You can verify that the amp is getting power by checking pins #3 and #9 to the connector on the amplifier. So, as long as you have 12 VDC there, then all the power input is good and leads to a bad amp.
if you have more questions, just ask.
42Ajd
12-30-2015 09:45 AM
FS[MidAtlantic]: 1997 XJ6 VDP - Very RARE Black on Black
42Ajd
09-21-2015 07:37 PM
