only get sound from tweeters
RE: only get sound from tweeters
The amp talks to the head unit and other units (speedo etc) via unique fibre optic cabling so it would need to be a Jag Cd amp unless changing the head unit too as far as I know.When I upgraded to the premium system in mine I get an error on the speedo as the amp needs to be coded to the car (security) via a dealer.Other stereo upgrades I read about havent had to do this so I must have been unlucky or the amp I got must have been removed from the donor car while the battery was connected causing the error.Still works though most of the time.Occasionally have to turn ignition off and on if sound stops.Will be getting this fixed hopefully at the X type seminar next Friday or if not will pay £50 at dealer to do it.
FS[MidAtlantic]: 1997 XJ6 VDP $3,900 - Very RARE Anthracite on Warm Charcoal
42Ajd
09-26-2015 07:04 PM
