Is it possible to install an connection to IPHONE in 2008 XJR?
if you do a seach on ACM on the forum you should find a guide on this. I am not sure how readily available the units are anymore but this would be your best route, as it will add usb and phono to your system. I have always just used the rear entertainment in the back to attach iphone to then away you go without having to install anything fancy.
well i have a long rca cable with a rca to stereo adapter on the end they only cost around a pound or a buck. I plug the Rca into the rear entertainment console and select the audio source to be aux input 1 or 2 depending which side you plugged it in. Then you make sure the button for car speakers is selected which is in the middle top of the console think it is a speaker button and might be a number key not sure if it is both. Then you just turn the stereo up and away you go. Then i just put my iphone or ipod on seat on in cup holder and away you go. Just sit in the back of the car if this doesnt work and have a fiddle with the buttons encase i got instructions wrong. I use this rather than buying the expensive ACM because it normally just use cds i only use this when have wife in car and she wants her ipod on as doesn't like my music tasteso its 5 bucks over 100 odd for the ACM
Also this is a link for someone installing an acm in the X350
https://www.jaguarforums.com/forum/x...-photos-50454/
Once you have the ACM you can go the whole route and install a mimics unit
This will give you the iphone or android mirrored on the nav screen
You can then also use your nav touch screen to control the phone
Check out http://www.customgadz.com/
34by151
34by151
