Rear Speaker XK8 1997
Guest
Posts: n/a
Hi There
New to the Forum and the Jaguar
Just bought a XK8 and noticed there is a speaker fitting in the rear parcel shelf where I assume a single bass speaker once sat (no longer there- just above fuel tank) Taped up are two sets of wires with push connectors which again I assume are for the missing speaker (Push connector 1 has two wires Yellow/Black and Pink/Black and connector 2 has two wires Pink/White and Green/Black) - Is this a special Jag speaker or can I go to my local Car Audio and buy the said beastie and fit it myself - any advice on size, spec etc.. would be much appreciated
Nick
Nick
RE: Rear Speaker XK8 1997
Greetings Nick,
That was a Harmon Kardon subwoofer fitted from the factory on cars equipped with the premium sound package. On the XJ, nothing else will fit because of the lack of depth.
I have a H-Ksubwoofer speaker grille from a '97 XK8 coupe, contact me off list if you are interested. Like yours, the speaker from mine was gone when I got the car.
No, I missed the year, sorry...it was in the title! 97coupe, got it. Pretty sure an 8" can fit, as the hole is just shy of a 10" opening (200mm is what the subwoofer size is from the factory), from what i remember.
I'd suggest either direct swap out with an 8" (w/ an adapter piece), or risk altering the hole permanently and getting a car audio place to cut out the hole for a custom fit 10". I'd do the 10", but thats just me. The car audio shop will help you pick a subwoofer make/model that is 'free-air' designed to work best with this type of installation.
Here's the wiring diagram...looks like you have the standard audio system, and if I am not mistaken, you will actually have to connect those wires to the amplifier. Doesn't look like it is pre-wired. If the existing amp doesn't have enough 'punch' to satisfy you (which it may not with an aftermarket sub, look to have a small mono amplifier added in the trunk to help you out.
More tips sure to follow. good luck.
Guest
Posts: n/a
Many Thanks for that info - I don't know what sound system is in it - but looking at the wiring diagrams you kindly sent I do have the fascia speakers, door tweeter, passanger door mid bass and the rear qtr mid range speakers as indicated in the Premium ICE diagram which all work
Regards
Nick
Regards
Nick
Can you post the wiring diagram again? It says the document is no longer available. I've got the same situation with my coupe - wires leading nowhere for the subwoofer and same with the dashboard tweeters. I found some small no-name tweets and a dual channel sub that will fit but need to know where the wires lead (where is the amp?).
Thanks!
Thanks!
I actually found this site in another posting which is perfect for anyone doing a sound upgrade to an older coupe: http://p4-8057.uk2net.com/jag/
In there he's got a diagram for the pin connector beneath the armrest that shows where to hook up a crossover network.
http://p4-8057.uk2net.com/jag/ArmRes...rConnector.doc
A full wiring diagram would be helpful though.
The JTIS CD has a full electrical diagram for every system, if you want to grab it sometime.
Here are the Entertainment pages for your 1997.
One of these days I'll save all of the MY electrical documents and upload them to our FAQ section.
intermittant sound
New question and I don't know if this speker related or not. 97 XJ6-R has HK sound system that infrequently and spontaneously radio stopped sound output for 1-4 minutes then resumed. Past week it stopped putting out sound altogether but the radio tuner appears to work according to the LCD and the radio auto tunes normally. Yesterday during a drive the stereo spontaneously came back on but I had to turn off car to go into library and when I restarted car no more stereo. Does any one have any clues?
Dave Halopoff
Dave Halopoff
99xk8guy
06-05-2023 06:28 AM
