Salvage Audio Upgrade?
So a salvage yard near where I live has the following speakers:
LH Front Alpine
LH Rear Alpine
LH Rear Deck Alpine
RH Front Alpine
RH Rear Alpine
RH Rear Deck Alpine
They're $55 each. Could I have these speakers installed and consider it a good upgrade or would it require more parts (Amp, Sub, etc)
LH Front Alpine
LH Rear Alpine
LH Rear Deck Alpine
RH Front Alpine
RH Rear Alpine
RH Rear Deck Alpine
Which car is this for? Model? Year? You would do well to get a look at the Jaguar Electronic Parts Catalog (EPC).
FWIW, on the X-Type, you're talking about speakers that would cost 3 to 4 times that dollar amount that you've quoted. Also on the X-Type, the rear-deck speaker IS the sub, and the tweeters are separate from the bass/mid-bass driver.
I expect that you'll also need the amplifier. And I have no idea whether or not these cars are pre-wired for the upgraded parts.
Forget the factory Alpine speakers, they don't sound the best & i've been told that after a while the magnet falls off ! the speaker frame...![Icon Saywhat](https://www.jaguarforums.com/forum/images/smilies/icon_saywhat.gif)
Have a look at a full retrofit of the original amp with aftermarket speakers https://www.jaguarforums.com/forum/x...ade-faq-64614/
In addition I believe that $55 for a speaker no matter what the name brand is extremely high for a salvage yard. I would expect that $15 tops should be what you would pay for each. Go to www.pullapart.com which is a nationwide salvage yard company and you can find the closet location to you and see what they charge. That should give you a good idea of what you should expect to pay. Good luck with your upgrade.
