Steering wheel audio buttons ?
I got a kenwood dvd,cd,mp3 player installed in my 01 S-type and the steering wheel buttons work fine..Except when the headlights are on..The volume and track up button dont work the mute and select and track down button work when the lights are on but the track up and volume dont work when the headlights are on..
Any ideas...
Thanks...Gary
Any ideas...
Thanks...Gary
Take it back to your installer.
The aftermarket steering wheel adapters are programmable. They sense different voltages when different buttons are pressed. When the headlights are on, the voltages vary slightly due to the changing loads in the wiring. He may need to adjust the switching points.
In addition to wrong propramming, it could have been grounded inapproriately.
krave (07-03-2012)
Thanks for the reply..I will diffinitely take it bake I talked to him today and he call the makers of the module that works the switches with no real luck they said sense the car was older..B.S...I will have him check the ground for sure.he programed the buttons correctly sense they work fine without the lights.But I dont understand when you say adjust the switching points could you explain that a little please..
Thanks..Gary
Thanks..Gary
First off make sure he grounded the adapter directly to the chassis, not some ground wire feeding another accessory.
Actually the unit self learns the switching points (the voltages the interface senses when different buttons are pressed) if he set it up correctly. Since it works, I would primarily suspect the grounding.
krave (07-03-2012)
FS[SouthWest]: Momo Wooden Steering Wheel
RobertTheBloke
09-24-2015 11:48 AM
1964Daimler
09-09-2015 11:28 AM
