Subwoofer install options for 2012 XF (base model)
Hello all,
Just wondering what my options are in regards to installing an aftermarket amplifier and subwoofer in my 2012 XF (base model)? Do you know where I can tap into a pre-amp full range signal? Or is there a subwoofer output I can utilize? What would you use for the remote turn-on? I would like to do it right the first time without hacking up the car. Any advise is greatly appreciated.
Thx,
Will
Thx,
Will
Definitely looking for the same answer here. I found this thread and saw that JJSAustin was able to successfully install an amp in his 2012. But I'm a bit confused on how to do it.
https://www.jaguarforums.com/forum/x...-system-61827/
I see you're in NJ. If you get this done, would you mind doing it for my car as well? Or provide a detailed description? I'd like to just add a simple 6" sub or a powered amp like this Blaupunkt.
Blaupunkt 6902A GT Power Series dual 6"x9" powered subwoofer at Crutchfield.com
Wolfy
05-28-2024 08:06 AM
