I had the car serviced today including the following: Total cost was $252.00 AUD I thought to have it done now as its a second-hand car with 104,842 klms. on it. Even though it has been one owner and all services being done by Jaguar dealerships, it was better to start my own records and peace of mind. I had the A/C Compressor replaced under warranty about a week ago. I did my own Air filter and Cabin pollen filter last week. I had the front and rear bumpers painted to rid the scratches from the previous owner had done. The cars looking great along with performing so much better with no more lag from the accelerator. EPA WASTE DISPOSAL FILTER FUEL RYCO {TRADE} FILTER OIL RYCO {TRADE} OIL ENVIRO + C1 {TRADE}
JAGUAR XF X250 2.2L AJ4D DIESEL
VEHICLE CONDITION REPORT:
1- CHECK AND ADJUST BRAKES, 2- CHECK TYRE CONDITION AND PRESSURE 3- CHECK SUSPENSION, BUSHES, JOINTS AND SHOCKS 4- CHECK ENGINE OIL LEAKS, 5- INSPECT UNDER BODY FOR LEAKS, WEAR AND CORROSION 6- INSPECT ENGINE BAY LEVELS. 7- INSPECT AND REPORT ON GEAR BOX AND DIFFERENTIAL OIL 8- INSPECT LIGHT, WIPERS, IN CAB ELECTRICS & GENERAL CONDITION OF VEHICLE. ENGINE OIL AND FILTER: DRAIN ENGINE OIL AND REMOVE OIL FILTER. SUPPLY AND FIT NEW OIL FILTER, SUPPLY AND FILL OIL AS REQUIRED. CHECK FOR ENGINE OIL LEAKS. FUEL FILTER: DISCONNECT AND REMOVE FUEL FILTER, SUPPLY AND FIT NEW FUEL FILTER. INSPECT AND CHECK FUEL LINES AND HOSES.
Had all the work on my rear suspension done yesterday and wow the Alloy in the wishbones and control arms are a work of art, the car had all the upper, lower wishbones replaced and the sway bar links along with the required wheel alignment and I have to say it feels like a different car. I know it was warranty work but I could not thank the car dealership more for paying for this and doing the right thing at such a big cost to them along with replacing the A/C Compressor with a brand new one only 3 weeks before so whatever they made as a profit has been eaten away or gone. We tried to get a cheaper alternative by buying just the bushes but in the end, this was the only thing we could find to get the car fix and on the road without too much delay. No one wanted to just replace the bushes so we as in the dealership had to buy the complete units and Being OME Jaguar parts it was not cheap. It is nice to think that a car dealership backs their cars when these sorts of problems come up. The A/C compressor was $1,300.00 then add the work below.
Rear suspension Jaguar XF: 02/04/2020
$4,567.50
Check the integrity of rear suspension.
Found control arm bushes worn and rear sway bar links worn.
Work carried out.
Supply and fit new upper genuine type control arms. Supply and fit new genuine type lower control arms. Supply and fit new genuine type sway bar links. Road test vehicle.
Sublet rear wheel alignment.
